X 51 and IMS
Old Jan 28, 2013 | 12:44 PM
kkswow12's Avatar
kkswow12
Default X 51 and IMS
do the early X51 cars run the same risk with IMS and RMS for that matter, or were they built differently... mine is a 2008 so i don;t worry about it, but would be good to know...thanks, as always, for the great insight imparted here...can't really imagine a more widespread and complete knowledge base for these cars...
Old Jan 28, 2013 | 01:18 PM
RollingArt's Avatar
RollingArt
Same IMS and RMS as other '08 M97 engines.
Old Jan 28, 2013 | 01:21 PM
perfectlap's Avatar
perfectlap
I was curious about this myself since X51 transplants seem to be popular for Cayman/Boxsters...
"Revised cylinder heads, new exhaust headers, camshafts with more aggressive profiles, a different Varioram intake plenum, and new programming for the Bosch Motronic engine management are utilized to add more grunt to the normal Carrera S's 3.8-liter flat six."
sounds like it's still in the 997.1 pool of potential for failure.
p.s.
Can you get an extended warranty from Porsche given that you're just out of warranty?
Old Jan 28, 2013 | 01:57 PM
alexb76's Avatar
alexb76
No, you got the upgraded IMS, so you're good to go! X51 was the best implementation of 997.1 engines. You're lucky to have one!
Old Jan 28, 2013 | 03:54 PM
Mspeedster's Avatar
Mspeedster
Right, depends on what "early" X51 means. X51 was introduced as an option in '06. All '06-'08 911 S cars have the same upgraded IMS bearing. I believe RMS is the same on all 997.1 cars. Early MY05 cars had the carry over IMS bearing design from the late model 996.
Bottome line, X51 neither reduces or increases the chance of IMS failure no matter which model year you have, it's the bearing itself.
Old Jan 28, 2013 | 04:28 PM
alexb76's Avatar
alexb76
WRONG! X51 comes on the later 997.1 engines which has the updated bearings, and NOT the earlier '05-'06 modesl with old bearings, prone to failure!
Old Jan 28, 2013 | 06:29 PM
Mspeedster's Avatar
Mspeedster
WRONG, X51 was available for MY'06 cars, which has the same bearing as '07-'08. Whether or not one can retrofit X51 to MY05 is another question.
As I said, it's the bearing that matters relative to potential IMS failures, not X51. You don't get a special bearing with X51, it's same bearing that normal S cars have relative to their model year. X51 gives no additional security over any similar model year S car without X51, or non-S for that matter.
Old Jan 28, 2013 | 08:08 PM
mdrums's Avatar
mdrums
X51 option package was about a ECU tune, Sport Exhaust, Headers, and some valve work and higher valve spring rate and bigger valves. Nothing really to do with the IMS bearing
Old Jan 28, 2013 | 10:21 PM
sclemmons's Avatar
sclemmons
My early X51 (new late 2005) has been a delight to drive and there is not a drop of oil outside the engine, even today.
Old Jan 29, 2013 | 07:23 AM
kkswow12's Avatar
kkswow12
skip, how many miles on yours,
Old Jan 29, 2013 | 07:30 AM
kkswow12's Avatar
kkswow12
i think so as well, i am so impressed with this car and i really don't have very much to compare it to, as far as other porsches or even other marques, but it sure makes me smile every time i even think about driving, me one lukkydukk kimosabi
Old Jan 30, 2013 | 05:15 PM
alpine-al's Avatar
alpine-al
Originally Posted by kkswow12
... me one lukkydukk kimosabi
Then, it seems that someone with a 997.2 S is even luckier than you. They've got 4 more HP and no IMS.
Old Jan 30, 2013 | 05:52 PM
kkswow12's Avatar
kkswow12
nobody lukkier than kimosabi, but if they are well then, gablesem
Old Jan 30, 2013 | 10:53 PM
sclemmons's Avatar
sclemmons
31,000.
Old Jan 27, 2014 | 06:22 AM
Henrik964's Avatar
Henrik964
Never heard of a x51 with failure though. Spoke to Porsche Sweden about it and they said they had not thougt about it but neither recall of any x51 with failure.
Anyone have input?
