997.1 trans drain plug
Need abit of help i was looking to change my trany fluid 6speed all the forums i have read it tells me the drain plug and the fill plug 16 mm and 18 when i removed the underbody panels what i see is a 24mm at the bottom and 24mm wich looks to be the fill , any help would be appreciated , thanks
yeah, i am running into that also - the shop manual says one thing but reality is different. maybe german models are spec'd with the allen type plugs. in any case, i found that a 15/16 socket fits just fine and am planning on changing it this coming wknd.
here are some good threads with pix (of the same plugs you and i are seeing):
https://rennlist.com/forums/997-foru...-location.html
http://www.6speedonline.com/forums/9...id-change.html
