Battery Maintainers
Awesome, I went ahead and bought the CTEK 3300 on Ebay. Even comes with the cig. lighter plug.
http://www.ebay.com/itm/190629049590...84.m1423.l2649
which mode do I leave it on when it's on storage for the winter? The car or the one with the snowflake?
1 Post
After the OEM battery died just after a couple years on my 997.2, I used a Porsche Charge-O-Matic. I just plugged it in the 12V outlet inside the car, and close the door. It worked pretty well for me so far.
And as folks say, the CTEK 3300 is essentially the same thing, and cost less.
It really, totally doesn't matter, a simple diode with power resistor (Household AC line...160 volts peak -14 volts = 146 volts at 2A max = 300 watt 73 ohm resistor.
not suggesting that this is anyone's solution, just an indication of how simple-minded an automotive lead-acid battery maintainer needs to be. Thus assumes that we're talking "maintainer" not charger.
As an electrical engineer I have designed a number of chargers over the years but I just bought a Ctek because it does what I need it to and I have better things to do with my time.
CTEK 56-263 Comfort Connect Cig Plug :
Well with a constant 2amps at the end of 3 months storage you wil have probably boiled all the electrolyte away.
50 watts wouldn't even "boil" an equal volume of water...
A maintainer like the Ctek uses a more complicated circuit to back the current off to near zero when the battery reaches full charge.
Another problem with your circuit is that with out a step down isolation transformer you may electrocute yourself or worse.
Did you not read, or you read but did not comprehend my second paragraph..?
If I had wanted to add the complexity of a transformer it would have been a simple 12 volt filament transformer. 18 Volts peak, only ~4 volts at low duty cycle (60 PPS) to "boil" the electrolyte if/when the battery is at full charge.
And finally: Not "dissing" Ctek compicated design by any means, just indicating that the <$10 one at Harbor Freight will work perfectly well, own 3.
Two questions. Where are people putting the ground when attaching the ground? Second question is what does the cigarette lighter option replace? I'm guessing you this is so you don't have to plug it into an outlet?
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
I was just making sure you don't have to connect the leads to the battery if you're using the cigarette attachment. I guess I don't get how it charges the battery if you don't attach leads to the battery?
Our Porsches are a bit unusual in that the cigarette lighter and accessory connection in the passengers footwell are always "hot". So it makes it a simple matter of plugging in the cig adapter into the cig lighter connection.
That's correct... you can just connect the maintainer to the cigarette lighter socket. Make sure to use the cigarette lighter and not the socket at the foot well. Optionally some of us have connected a line directly to the battery terminals... running the line up through the windshield wiper cover.
Wwest
I don't want to make a big deal out of this but a continuos current of 2amps will not boil the electrolite away it will none the less turn it into H and O and it will be gone. This is why they designed maintainers instead of trickle chargers to cure this issue for long term storage.
I think if you are going to store your car for a long period it is just good practice to use a good maintainer. There are ones that are as little as $25 that will probably work fine.
However if I'm going to leave something plugged in my garage unattended for 3 months with a typically wet salty floor in the winter, I will opt for a well built unit.
Provided the cigarette lighter remains "powered" with the ignition key removed the battery maintainer can be connected to the battery via the lighter socket. no need to leave the front lid open.
