Battery Maintainers
I usually drive my 07 C2S enough that I don't need a battery maintainer, however it's been so cold and icy here I haven't been able to get the car out for 2 weeks. I figure I probably need to pick up a battery maintainer. Should I go with the Porsche one is there something else I should be considering? I think the Porsche one is a cigarette lighter one. My car doesn't have the notch in the weatherstripping, how do you run it through the door if you don't want to keep a window down?
I believe the CTEK 3300 is the OEM'd version of the p-car maintainer if you want to save some $$. I installed a hard wire line(with fuse) to the battery directly and then ran the line through to the windshield wiper cover/tab. Easy to access from the outside and I connect her up everyday. Thought I would have to replace the plastic tab by now but it's still working properly after almost 2 yrs of ownership. Just make sure to disconnect and cover it up properly with the plastic cover/tab each time before going out. GL.
![Name: 2013-01-02_09-11-33_336.jpg
Size: 74.5 KB](https://rennlist.com/forums/attachments/997-forum/692001d1357140052-battery-maintainers-2013-01-02_09-11-33_336.jpg)
![Name: 2013-01-02_09-12-00_860.jpg
Size: 181.6 KB](https://rennlist.com/forums/attachments/997-forum/692002d1357140052-battery-maintainers-2013-01-02_09-12-00_860.jpg)
I would recommend a battery maintainer instead. Disconnecting the battery requires a very specific series of actions to get back into the car. Do a search or read up on this procedure in the owners manual... it's a real PITA as some forum members have had the displeasure of learning after the fact. Plus having the car alarm enabled is a bit comforting for security purposes.
If not there are numerous extension and connector options if you have a Batteries ETC store nearby. Otherwise Amazon or ebay is the way to go. I spent a little more(about the same as I would have for the p-car branded maintainer) to get a Battery Minder 12248 which was more capable and included all the options.
^^^ This
I've just been plugging mine into the cig lighter for 5 years now. No problem.
Awesome, I went ahead and bought the CTEK 3300 on Ebay. Even comes with the cig. lighter plug.
http://www.ebay.com/itm/190629049590...84.m1423.l2649
which mode do I leave it on when it's on storage for the winter? The car or the one with the snowflake?
It really, totally doesn't matter, a simple diode with power resistor (Household AC line...160 volts peak -14 volts = 146 volts at 2A max = 300 watt 73 ohm resistor.
not suggesting that this is anyone's solution, just an indication of how simple-minded an automotive lead-acid battery maintainer needs to be. Thus assumes that we're talking "maintainer" not charger.
