tight turn = rubbing/grinding?
Hey all, happy holidays!
Quick question. Hopefully someone has insight. The other day when i was in a parking lot and turning in a circle to go back to the exit i realized that if i turn the steering wheel all the way left or right to its limit and then drive in a circle it feels as though something is rubbing or grinding up front...could feeel it through minor vibratoions and if i recall correctly, slight noise accompanying it.
I have the standard 18 carrera ii's on it i believe.
Any thoughts? Is this normal?
Is your car all wheel drive?? Does it feel the same way making a sharp left turn?? If so that is norman for an all wheel drive model. I have a Targa 4 and I get the same thing making sharp turns in either direction.
Steve in Saratoga Springs, NY (where we might get 12-16' of snow tonight)
it could just be the tires slipping on the pavement. When the wheel is at full turn, the rolling radius is not exactly perfect so you can "slip" a bit. The tread sliding and grabbing the pavement can feel a lot like grinding. To be sure, jack up the car and look real good at the front tires, inside and out. Just look for any signs of the tires hitting anything.
sorry guess i shouldve provided more detail. its a c2...not awd. And it happens on any type of pavement and ive done it a few times, i feel it more when i bank it total right and drive in a circle. i banked it fully left and drove it a circle and feel it too but a little less.
Poseur
Have you got the normal sized tires on it? You haven't put anything larger than called for on it?
These cars shouldn't do that--how many miles on the car? Maybe need to tighten up suspension pieces.
All 3 porsches that i have owned (06 Boxster, 08 Cayman S, and now 06 C2s) have done this making sharp slow turns when it is cold out. I was also told this was normal on other forums.
my new 981 does this too.
