Lobster Claw Wheels
Old Dec 16, 2012 | 09:29 PM
nigel911's Avatar
nigel911
5th Gear
Default Lobster Claw Wheels
Looking for a set of Lobster Claws for my narrow body C2, was hoping someone might help clarify part / sizing - is this correct?
NARROW BODY / S
Rear Size: 19x11
Offset: 67
Part No: 997.362.162.01
WIDEBODY / 4S
Rear Size 19x11
Offset: 51
Part No: 997.362.162.00
Would the 51 offset fit a narrow body?
Old Dec 16, 2012 | 10:50 PM
X51's Avatar
X51
The 67 offset is the correct rear wheel for your car, per Porsche spec.
The 51 offset will be pushed out equal to or beyond the fender wells before consideration of tire size.
Old Dec 16, 2012 | 11:03 PM
X51's Avatar
X51
FYI: If you want fitment flush with the fender well without spacers, here's the recommendation of HRE, the wheel maker:
Front 19x8.5 ET51 235/35-19 Tire
Rear 19x11 ET56 305/30-19 Tire
Old Dec 17, 2012 | 12:27 AM
nigel911's Avatar
nigel911
5th Gear
X51 - appreciate your help, as I thought, those wheels may look a little odd on a narrow body. Was enquiring as there is a set advertised as 'will fit a narrow body', they may well fit, but not look quite right.
Old Dec 17, 2012 | 01:17 AM
gla's Avatar
gla
nigil911.... I have a flawless set of black powder coated lobster forks from my NB 07S. If you are interested send me a message.
Old Dec 17, 2012 | 04:44 AM
purrybonker's Avatar
purrybonker
Also , I have a set of original lobsters from my '06 C2s with almost new snow tires (less than 1000 miles) that I could part with. I never seem to get around to mounting snow tires in Vancouver. Damn global warming - no snow these days...
Old Dec 17, 2012 | 09:34 AM
ELUSIVE's Avatar
ELUSIVE
I see you are in Boulder.
I have a set of Lobsters from my narrow body 997S in Broomfield.
Perhaps we could work something out.
They were used for 9000 miles and removed. They still have Pirelli Pzero tires on them but they are essentially worn out in the rear.
Old Mar 2, 2026 | 12:02 PM
ClubublC4S's Avatar
ClubublC4S
2nd Gear
Default Lobster Claw Wheels for 2006 C4S
Hey all, I am confused to what size I should be looking for in these wheels for my 2006 C4S. Can someone give me the proper size front and Rear before i buy?
Ones I am looking at are
Front 19x8+57
Rear 19x11+67 will these be fine?
Old Mar 2, 2026 | 12:58 PM
Yorik's Avatar
Yorik
Front 19x8+57
Those are narrow body offsets.
Old Mar 2, 2026 | 02:00 PM
knock1's Avatar
knock1
@ClubublC4S Owner Manual is your friend
