Battery Tender Issue
Old Dec 12, 2012 | 11:14 PM
stacheman's Avatar
stacheman
Default Battery Tender Issue
I have the battery tender that the porsche dealer sells. It has worked well for the past two years however now the only light on the display is the power indicator. It does not allow me to select mode.
Does anyone know if there is a fuse in the lighter adapter piece on the charger?
Old Dec 13, 2012 | 01:14 AM
P0rsch3F113's Avatar
P0rsch3F113
Not sure but the Porsche battery maintainer I saw at the dealership last April appeared to be a re-branded CTEK maintainer. Check their web site for the particular model you have, or this site for the manuals: http://smartercharger.com/manuals/
Old Dec 13, 2012 | 04:56 AM
boolala's Avatar
boolala
Good question. I have a CTEK branded unit and the lighter adapter stopped working. The battery terminals still work, however. The latter is fused. If there is a fuse on the cigarette adaptor it does not appear to be accessible.
Old Dec 13, 2012 | 08:59 AM
jhbrennan's Avatar
jhbrennan
Not completely familiar with the CTEK but many cigarette adapters do have a fuse - usually accessed by unscrewing the tip of the adaptor.
Old Dec 14, 2012 | 07:48 PM
SToronto's Avatar
SToronto
CTEK makes the Porsche charger, it's the multi US 3300. Was advised that the 4.3 also works, it's newer and what I have.
Try emailing or calling ctek for help.
Old Dec 14, 2012 | 10:53 PM
CAVU's Avatar
CAVU
On the side of the cig adapter on mine is an 8 amp symbol. It appears that you unscrew the small Phillips screw on the side to access it. I tried to see if plunger at the end was keyed, and it appears to be too small to accommodate the fuze that way.
Old Dec 16, 2012 | 01:27 AM
boolala's Avatar
boolala
Sure enough. Removing the small side screw allows one to pry open the cigarette adapter and exposes the spring loaded white fuse (below). Tested mine with a continuity tester and it's dead. Thanks for the tip!
File Type: jpg
File Type: jpg
Old Dec 16, 2012 | 10:39 AM
fskof's Avatar
fskof
Good Job. now replace the fuse and it will be good as new
