Is it safe to go through a car wash?
Hi,
Winter is here and it's just too friggen' cold... otherwise I'd be washing my car by hand.
I consulted the owners manual, but there seems to be no definitive answer.
In my 996 and 986, the manual clearly stated that car washes should be avoided (due to water getting in the air intakes either on the tail of the 996 or the side scoop of the 986), however in my 997.1, there is no specific mention of car washes. It just states "if washing by hand...etc"...
this leads me to believe that the car can be driven through a car wash (especially since the slats on the rear deck no longer face the same direction/angle as they did on the 996)?
Am I correct in assuming this?
There are some people here who do this. It should be significantly less hard on the car than all the grit that gets kicked up on the highway. My main concern is the tire size. Not sure if all of them can take it. Let me know if you find one.
I'd go to the $2.00 hose it down car wash before brushless or any other car wash
a detail guy told me recently that he'd never let anyone wash his car unless they had new mit and new micro fiber towels for each and every washing....made sense. avoid swirls and go with a proper detail
Hi,
Winter is here and it's just to friggen' cold... otherwise I'd be washing my car by hand.
In my 996 and 986, the manual clearly stated that car washes should be avoided, however in my 997.1, there is no specific mention of car washes. It just states "if washing by hand...etc"...
this leads me to believe that the car can be driven through a car wash?
http://www.optimumcarcare.com/onrwns.php
I just got the Optimum no rinse and will give it a try on Sat. Still, come January that bucket of water will be frozen by the time you're done. The existence of a garage is not always a valid assumption.
Basic Sponsor
If you absolutely positively cannot do this otherwise, find a brushless place without the wheel guide....drive in, let it spray you down, drive out, etc.
Other than shooting water in places it would not normally go, this is the least harmful of the options you may have.
Detailing Dynamics in Mineola is an hour or so from you. Go there if you can't resolve locally.
I never ever go through a car wash. Never. I will let my cars get dirty as hell (and yes, it makes me squirm) but I know what these places can do to your finish.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
The guide rail height is most likely higher than your sidewall. This means your wheel will drag the entire length of a steel rail through the carwash. If the rail does not have some kind of coating or protective cover, metal on metal will cause damage. That's if your wheels fit into the guide to begin with.
Former Vendor
I know it's hard, but if you go through car washes it WILL damage your paint. And it only takes once through a dirty one to do damage it will take hours to correct. REMEMBER!!!
![Name: Picture086.jpg
Size: 131.9 KB](https://rennlist.com/forums/attachments/997-forum/1207143d1501352529-is-it-safe-to-go-through-a-car-wash-picture086.jpg)
