DIY Stone Guards - failure
Old Dec 1, 2012 | 08:36 PM
cvtbenhogan's Avatar
cvtbenhogan
Default DIY Stone Guards - failure
Tried replacing stone guards today. Complete butcher job.
Tiny specks of trapped dirt caused me to reposition and peel off the film repeatably. Now the driver side film has a cloudy appearance as the glue went bad. Yikes. The other bozo move was using a foam window cleaner, which leaves traces of micro foam that I couldn't squeegee out. The passenger side isn't as bad as I got the hang of it on the second install.
I'll reorder the film and try again. Next using lightly soapy water. Tomorrow I'll eyeball the passenger side and see if its passable, if there is enough daylight. Might have give this up to a pro.
To add insult to injury, I went to Westmont porsche and they charge a whopping $163 for one stone guard. These are $40 each on Suncoast. I couldn't be persuaded and said good day to the parts guy.
BTW. Saw the new Boxster and it looked great. Really look forward to seeing the new Cayman in the person.
Old Dec 1, 2012 | 08:41 PM
Lvt19672's Avatar
Lvt19672
Sorry to hear the install went bad, I just ordered a set from suncoast and was going to DIY but now I'm having second thoughts.
Old Dec 1, 2012 | 09:24 PM
saabin's Avatar
saabin
The body shop guy did mine when I picked up my painted aero spoiler that I had refinshed. He did it for free and took him about 20 min. (most of that was heating up the panel with a heat gun to peel the old one off as it was only 40F outside that day..
Old Dec 1, 2012 | 11:53 PM
okbarnett's Avatar
okbarnett
Keep the job clean. Polish off the body and make sure its free of any haze and marks. Squirt on the liquid, like alchol and water, or light soap and water. Peel off the guard and dont let anything touch it. Squirt the sticky side of the guard with liquid and lay it on the car. Manuver it in place and start squeeging it from the middle to the outsides.
I dont use a squeege, I use a damp cloth that I can ball up and press and slide against the clear.
