DIY Shift Cable Diagnostics and Replacement
#46
You ever get an answer to this? Changed the transmission mount on my 03' GT2 and noticed one of the shft cable ends was very loose, could move it back and forth while connected very easily and shifting into 1st often requires double-cluch action and 2nd is starting to miss. Both issues may be unrelated but seeing the loose cable end, I want to replace at minimum.
http://www.function-first.com/produc...ter-cable-ends
#47
Basic Sponsor
If you are experiencing excess play from the stock cable ends, and/or worried that they will pop off due to age, you can replace the internals with the tightly toleranced aluminum/Delrin Shifter Cable Ends from FFP. Install is easy - it can be done from under the car pretty quickly.
Please reach out with any questions - thanks and stay safe!
Comprehensive Shifting Solutions for your Porsche.
#50
Thanks!
I made an account just to say that this DIY saved the day for me! My cable broke in exactly the same spot, and I also had to drive home with just 3rd gear. I followed this DIY, and I am now once again selecting gears using the shift lever of my motorvehicle! Thank god for the internet. Everything was pretty easy *except* pushing the new grommet/gasket thing in from under the car. That part sucked!
#51
Thank god for this DIY, this and the Numeric guide got me through the job. Lost all gears a couple of weeks back in my ‘06 997 S, figured that I had snapped a cable so I ordered some Numerics rather than go back to the OEM. Stupidly I didn’t bother to remove the under trays until yesterday and once I did I realised that it hadn’t snapped, but just popped off the linkage. Regardless, with the new cables in hand I decided to do the swap and never have to worry again.
Much easier job than I thought it was going to be, until I got to the point of reinstalling that bloody rubber bushing. Words cannot describe the frustration. On a side note, thank god for “urdreamgarage” in LA, renting a lift was an absolute life saver, I don’t think I could have done this on jack stands.
Overall very happy with the upgrade, the mechanical feeling is a huge improvement from the OEM mush. I also used the silicon tubes and the noise increase is minimal, though some “chatter” on throttle lift off is noticeable.
EDIT: After getting home and reinstalling my center tunnel, there is absolutely no increase in cabin noise from these cables, the silicon tubing obviously did the trick.
#53
Porsche shift cables
@Insomnic , the images that aid your writeup are not loading. Any chance you can resolve? I need to replace my shift cables and it appears this is the best DIY.
Thank you in advance.
i am not sure i can help but i did replace my entire shift system with the numeric one
#54
Thank you for your willingness to lend direction / advice.
#55
@Tsmith5150 I haven't started the process; I am researching to gauge if it is within my skillset. The images will help me to fully understand the scope of this DIY.
#56
its not too bad. They may have you tube videos. I am pretty good DYI guy but no master mechanic. The new Numeric shifter is made strong and well designed. It will be a tat bit more like a riffle bolt shifting. Kind of cool. Not soft like a honda. The toughest part was fishing the cables under the console out under the car to the gear box. That was a pain. Connecting is the cable to the shifter and the gear box is fairly simple. These cables are strong and will probably never break. Its a thicker gauge. Check out you tube and see if there is a video. I am sure they are.
