Help me convert my 997.1 C2S to an X51 equipped C2S
Nope.
Not required, I am changing just intake manifolds, plenum and throttlebody, people change plenums and throttlebodies all the time with no issues, if I have an issue I can speak to Softronic for a tune.
I can do the install myself, its not complicated!
Intake manifolds 4hr-6hr job, change spark plugs at same time too.
Plenum - 30 minutes
Throttlebody - 30 minutes
A Porsche veteran would do the above in sub 4hrs quite easily.
Plenum - 30 minutes
If you did the work yourself, then maybe it makes sense, at least the parts are proven... keep us posted on the progress and results. PLEASE do a Before/After Dyno, otherwise, there's no way to know if it made any difference.
You 100% need ECU program, ECU will learn within a set of boundaries, it's not magic. X51 has a totally different Torque curve, and needs a new program to adopt to the increased airflow, etc.
The ECU re-programme is not needed to run though, I could nicely ask Porsche for the programme but my car won't be full X51 as its still missing the revised cylinder heads etc.
The stock ECU tune will adapt a little so all runs well, just might not get the full advantage unless one gets the X51 map or uses softronic.
So now I just want to add the intake manifolds, X51 plenum, X51 throttlebody, thats it just along with all the accessories required which is gaskets, tank vent hose etc.
Hello, I know is an old post, but I find myself in need of replacing the intake distributor pipe (997.110.416.40) on my 2007 C2S. I would rather eat glass than visit my local Porsche dealership ever again (long story). Can this be purchased online somehow?
Ken
I had an '07 C4s X51 (still my user name). Before that I had an '06 C4s stock. Other than PSE, I really couldn't tell the difference! 26HP sounds significant but in reality it is about 7% more which really isn't all that noticeable. And the factory X51 engine is so much more than some bolt on add ons. If you want an X51 engine, I recommend you buy a car already optioned from the factory. The dealership here in Louisville KY has a Seal Gray on full leather sport seats in black '06 C4s coupe w 42k miles for sale! Don't get me wrong, I like to mod & personalize my cars too, but something's make sense and some things make no cents ! GL
