How to question...
Old Nov 17, 2012 | 11:12 PM
Sugar997's Avatar
Sugar997
Default How to question...
How do I remove the seat release (the ones that flip the seat forward to enter the rear seats)? They rattle and I want to put some felt between the latch and the seat.
Can't find anything on how to do this on the forums or when I google it.
Thanks!
Old Nov 18, 2012 | 08:34 AM
Little Green's Avatar
Little Green
I had the same issue and could figure it out so I grabbed a black hair tie(those little elastic black ones kids use) and wrapped the stem a couple of times. It shrinks itself around the stem behind the handle and you can't really tell its there.
Old Nov 18, 2012 | 11:34 AM
Ptech1's Avatar
Ptech1
While lifting the lever, you will need a screwdriver thin enough to fit through the slot in order to pry up and towards you on the hook/tab of the actual **** to release it. You may want to cover the actual surround with a rag or wrap the screwdriver in electrical tape, etc in order to not scratch it. Then the tabs of surround just need to be carefully released from between it and the seat for removal. Everything just clips back together when reinstalling. Hope this helps!
Old Nov 20, 2012 | 07:59 AM
Sugar997's Avatar
Sugar997
Thanks for the answers. Short term, my daughters hair pulls and long term I will remove and add felt.
