Production date and ims
Old 12-08-2012, 02:17 AM
  #31
Papa Fittig
Papa Fittig's Avatar
Originally Posted by holden997
that's correct,
I did some digging into the 997 work shop manual and extracted the following information on which engine has the old or revised larger IMS bearing:
Base engine (3.6) has designation "M96", has both the older IMS and revised larger bearing, you will need your engine number to determine which one you have:
Engine (3.6) number up to M96/05 69507475 has the older IMS bearing and Engine number from M96/05 69507476 has the larger revised IMS.
"S" engine (3.8) has designation "M97", also has both the older IMS and revised larger IMS bearing:
Engine (3.8) number up to M97/01 68509790 has the older IMS bearing and Engine number from M97/01 68509791 has the larger revised IMS.
The older IMS bearing can be replaced, this requires removing the transmission in order to get access to the bearing.
The larger IMS bearing can also be replaced but a tear down of the engine is required.
The work shop manual does not mention the date for the IMS changeover.
Thank you for the info. This is THE most useful post for the IMS bearing issue I've seen.
gbworks (05-10-2023)
Old 02-09-2022, 12:21 PM
  #32
vanlieremead
vanlieremead's Avatar
Default 2005 Boxster S
Originally Posted by mgordon18
I found this post over on 6speedonline. Skip down to post #8.
If someone can post up an example of an M96 engine on a 2005+ Carrera S or 4S, I'd love to see it. Similarly, I'd love to see an M97 engine on a non-S car.
ok, not a 997 but a cousin S M96
Old 02-09-2022, 05:31 PM
  #33
groovzilla
groovzilla's Avatar
Received 4,971 Likes on 2,941 Posts
Engine # stamp on drivers side of engine case - Easy to see/read when bending under rear tire on drivers side.
Here's a better photo:
Sometimes hard to read sometimes not depending on oxidation/etc.
Quick Reply: Production date and ims
