Swapping TPMSs?
Barring damage, how stable/sensitive are TPMSs when swapping from one wheel to another?
Is there a correct procedure to follow or plug and play?
In a recent thread there was some mention of a rated life for TPMSs? How long? Can the batteries be changed?
Finally, should/will the vehicle automatically read the TPMSs or will there be possible issues?
I have TPMS in my street and track wheels. I just go to TPMS menu and click set and then drive and the car picks up the new set of TPMS no issue. For my understands it seems like battery life is around 7ish years.
No issues. Have swapped, etc. on several cars. Do you have a 997.1 or .2?
.2's reset in about 2 blocks. .1's seem to take forever but was probably on a few miles. It was like watching for water to boil on my .1.
Took the new sensors to the dealer to find out why they didn't work on my car. The serial numbers on the sensors were checked against my VIN # and they were not compatible. The advisor said the sensors have been produced with 4 different frequencies over the years and the only way to assure a good match is to check serial # of the sensors against the VIN # of the car.
I could be wrong but I have heard that .1 TPMS systems have the (4) different frequencies as sandswedge mentioned. .2 are .2 without this concern. I bought some used wheels with tires and .2 sensors and could switch between my .2 sets without issue. Maybe it was just dumb luck. No question you can't mix .1 sensors with a .2 receiver.
