Deflated tire from puncture at home- what's the best move?
If I go to the dealer route it would be P of Fremont.
beden 1, Devil boy..good points, thank you..
Never knew about the mushroom method Damon@ tire rack...will ask about this... Thanks so much guys!!
I have the worst luck with getting screws and nails in my tires. I get about two a year between all my cars. If I were you I'd first try to fill it up the tire back up. If it's a slow leak you can drive to a local tire repair place that you trust. I get mine repaired all the time at one of two local places.
My challenge is that due to local tire shop (Discount Tire) scratching my wheel (Custom painted HRE's) just to patch a tire, I will now ONLY go to dealer as they have a machine that never touches the wheel during removal/installation.
I wish I could unfortunately I've been out of town..should be back in an hour to try and resolve this as I just landed.
Many problems can result from plugging a tire from the outside. One of the most common is inserting the tool used to install the plug causes more damage than the original nail etc, often this introduces moisture into the plies, (steel belts anyone) which leads to rusting &/or seperation of the tread belts.
Plugging a tire instantly voids tire warranty.
I find that producers of quality tires for sportscars i.e. Goodyear, have the proper equipment to handle low profile, wide tires without damage. Therefore, my local Goodyear shop has patched a 275/30/19 and a 295/30/19 with no problem. Most reputable shops wont touch plugging tires like ours because they know of the dangers. Patching, and only in certain areas of the tire, is a valid repair.
Places like Discount Tire may not have the proper equipment resulting in damage. They just sell tires, and most likely rarely, if any, in our needed sizes.
I'd take the wheel off and bring it to them. This way, you don't have to wait for and worry about lift procedures, and of course someone else driving the car.
In a separate incident, AUDI failed to properly torque a front wheel, post suspension repair. All 5 bolts were not seated allowing the wheel to bang back and forth by maybe a millimeter. It seemed like an inch though the way it felt. Moral of the story is I 'm in better control of many things when I limit any repair facility's interaction with my car.
I once picked up a nail on the 100 mile drive to my Porsche dealer to have my annual servide done. To this day it annoys me that they sent me home on it with the nail still in the tread rather than patch it for me, like I asked them to. It was a Boxster I knew I wasn't going to be keeping too much longer, so I really didn't feel like spending money on 2 new rear tires (since they were worn).....
So yea, Porsche dealers will not patch a tire. Trust me.
Landed today and prior to going to the local Wheelworks, I had to use the sealant compound from the car and compressor to bring it to 44psi as the tire was down flat again.
I've been a long time customer so they took me in right away with an appointment done in 20mins. They dismounted the tire and did a combo patch/plug fix ..short drive home TPMS pressures were holding well. I wont get to drive it far and at high speeds until I return next week (one last long week of work) then I'll finally know the quality of the work, They charged nothing
Poseur
We visited this topic several years ago repeatedly when the 997 first came out. Porsche will generally not plug or patch a tire--liability concerns drive everything these days.
If you can wait until you return, do that.
I absolutely do not trust tire shops with my car. Period. What I will do it jack up the car, pull the wheel(s) and take it (them) into a tire shop for repair or replacement.
How you drive your car can affect how you chose to repair it. I took a hit years ago on my 1981 Turbo and I was so ticked off that I had just put new tires on it within the month. I had taken a large steel wire (and I do mean large for a wire) in through the tread, and it wound up poking out through the sidewall. Any sane Porsche Pilot would tell you to replace that tire--but I'm not that sane, so I had the tire patched, and also put in a tube. The tire performed beautifully throughout the rest of that set of tires' life. If you are not squealing tires up and down Route 1 then just patch it from the inside and go for it. If you do driving events with your club then just buy a new tire if it bothers you. Unless you specifically have wheel and tire insurance for your car the dealership will wind up replacing that tire. (I got the wheel and tire insurance for up to 100,000 miles and ten years with my extended warranty).
Plenty of independent tire shops have equipment equal to or better than the dealerships. I've used one of them for the past 5 years and they don't even leave fingerprints on the wheels when they're done. Less than half the cost of what the dealer charges.
