Headlight gasket - Is it sealed?
I decided to look into the headlight bulb changing process. In examining the headlights, I noticed that they are only sealed on the top 2/3 of the light module to the car's body. The bottom does not have any gasket at all, and water and other contaminants are free to enter the cavity under and around the headlight. Now, the headlight module is sealed in itself, but this seemed like an odd design choice.
Does anyone have any idea why this was done?
Poseur
The Bi-Xenon section is fully sealed. It's ultimately best not to attempt to seal up areas that are not affected by moisture because it would require a lot of moisture sealing and maintenance. Only seal up what is critical. The other areas are just not that critical. Anyone who has taken out their headlight assembles can see that.
Poseur
My guess would be that there is so much heat generated inside those housings that there must be allowances for thermal expansion and venting.
btw- beautiful color on your pcar. love it.
Bi Xenons are also high voltage, can't imagine what moisture would do ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
My rear lights fog up after a few days of rain when I start the car, although car is garaged, it dissapears after some time of driving.
