Oooooh, that seems awfully low to me. He said track day, not autocross!
I'd suggest you start at the recommended pressures for the tire and work up or down from there as needed. Ask your instructor for help.
Bring lots of water. Drink lots of water during the event. Brake fluid flush, not bleed, if it hasn't been done recently. As mentioned, a general tech inspection to make sure that everything is OK.
My mistake, you actually made me check my tire log book. Cold psi is 27 all four corners on my Boxster and hot psi is around 34-35. I apologize.
