rear brake cooling duct
FYI, if you have nothing there at all - you need to put this one on.
http://www.suncoastparts.com/product...7brakeupgrades
one from RS car is more efficient but costs $200+. this one above is just $49.
but you can mount them both if you keep overheating rear calipers.
http://www.suncoastparts.com/product...3BRAKEUPGRADES
Agree with the OP that more cooling is required. Especially on the rear where PSM overworks the brakes.
Former Vendor
They're really not going to help the cross-drilled holes. Those will plug up anyway. They may help get more airflow through the vents, keeping them cleaner.
Former Vendor
The Turbo ducts don't move as much air as the GT2 ducts, and direct the air at the calipers. GT2 RS ducts are more effective, and direct the air at the rotor itself, providing you with superior cooling and increased air flow for your rear braking which will lead to longevity in your pads and rotors while increasing braking sustainability.
