Oil Filter Inspection
Hi Folks,
I performed the third oil change @ 11k on my 2007 997S. I took this opportunity to install the LN Engineering spin on oil filter kit and magnetic drain plug.
Upon inspecting the used oil filter, I found a single little piece of debris (looks to be metallic) nested inside one of the pleats. The last time I changed the oil, I also had a single piece of debris in the oil filter.
Cause for concern? What could this be?
Here are some pics:
Here are some pics:
Is it metal, is it ferrous, is it plastic? If its aluminunum, its not a problem, even if its ferrous, its so small and only one bit that I wouldn't worry about it, same thing for plastic.
I think its pretty normal to get small bits of debris, ferrous, non ferrous and plastic all the time.
