Porsche 997 Carrera 2004+ Coilovers Road & Track by Ohlins from GMP Performance
![](https://www.gmpperformance.com/CFJFiles/GMP/26287_b.jpg)
Road & Track by Öhlins
This is the latest step in the Öhlins Racing automotive philosophy – Road&Track by Öhlins. A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over! We have also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have suffered through vast corrosion tests according to ISO9227. The end result is a 2-year limited warranty on all of our products - worldwide.
General Features
DFV (Dual Flow Valve)
Rebuildable
Corrosion salt spray tested (ISO 9227)
2 year Limited Warranty
Height adjustable
Front
McPherson Strut
Single bleed adjuster
Spring preload adjuster (approx. 25 mm lower than standard 996 Carrera/997 Carrera)
Coil Springs (60N/mm Carrera models)
Dustcovers
Use with original top mounts
Rear
Conventional Shock Absorber
Coil Springs (120N/mm Carrera models)
Dustcovers
Spring Rate - Front: 60 N/mm(343 lbs/in.) Rear: 120 N/mm(686Lbs/in.)
The Features Of DFV Technology
So what is DFV? It is Dual Flow Valve technology – and it sets us apart from our competitors. Only Öhlins has DFV technology on its road and track products.
With DFV, the dual flow valve gives the same characteristics on rebound as it does on compression, thanks the damper fluid having a consistent path of flow in both directions. This means that the wheel and tyre can quickly and effectively resume their important position back on the ground, providing grip and traction. The new Öhlins R&T range uses DFV technology on every single fitment, making it the perfect upgrade for the enthusiast that needs comfort and agility in the one unit.
![](http://www.roadandtrackbyohlins.com/wp-content/uploads/2009/08/rt_dfv_fig1_2.jpg)
Figure 1: (Compression flow) At low shaft speeds, oil flows mostly through the shaft jet bleed (lower dotted arrow). At higher shaft speeds, oil flows mostly through the compression ports in the piston (upper dotted arrow). At very high shaft speeds, or during sudden shaft accelerations, oil can also escape through the compression ports in the DFV, increasing comfort. Figure 2: (Rebound flow) At low shaft speeds, oil flows mostly through the shaft jet bleed (lower dotted arrow). At higher shaft speeds, oil flows mostly through the rebound ports in the piston (upper dotted arrow). At very high shaft speeds, or during sudden shaft accelerations, oil can also escape through the rebound ports in the DFV, maintaining tyre contact with the road.
Because DFV opens more quickly and easily on minor road imperfections, ride comfort is surprisingly supple and more akin to an OEM strut than a coilover set-up. Over undulating surfaces, the compliancy of the R&T units allows the car to crest bumps and pot-holes, whilst still keep stable and in control. Traction is always maintained at its optimum level. When comparing suspension, why settle for second best?
![](http://www.roadandtrackbyohlins.com/wp-content/uploads/2009/08/rt_dfv_fig3.jpg)
Figure 3: (Vehicle – no DFV) Without DFV the oil can not flow through the piston quickly enough on the rebound stroke after hitting a bump, so the tyre is not able to stay in contact with the road.
![](http://www.roadandtrackbyohlins.com/wp-content/uploads/2009/08/rt_dfv_fig4.jpg)
Figure 4: (Vehicle – DFV technique) The DFV valve opens, letting the oil flow quicker through the piston on the rebound stroke after hitting a bump, enabling the tyre to stay in contact with the road.
When adjusting ride height on coilover units, it’s worth comparing how it’s done. On many inferior designs, height is adjusted by raising or lowering the lower spring platform. This has the effect of compressing or extending the spring, which can limit the suspension travel that may cause topping out. The Öhlins method is to leave the spring seat in its perfect position, whilst the lower flange spins easily on the threaded body, to allow you to adjust with absolute precision whilst maintaining the perfect characteristics that we took so long to design in! Once you’ve set it all up, the adjuster simply locks off to maintain your exact settings.
Dampers will get hot. That’s one thing that you can be sure of. As the piston moves within the damper, it generates friction – and therefore, heat. Although we can’t stop heat, we can deal with it, and this is yet another way that Öhlins differs from the competition. As the heat increases, the viscosity of the damper fluid can change, altering the car’s handling characteristics. Our unique needle bleed valve expands with temperature, closing the gap that the fluid travels through, maintaining a consistent damping rate. The best thing of all? You won’t even notice! All you’ll feel is that the car responds consistently, lap after lap, turn after turn. Allowing you to concentrate on braking points and apexes whilst the Öhlins technology takes care of the damping.
![](http://www.roadandtrackbyohlins.com/wp-content/uploads/2009/08/rt_dfv_fig5.jpg)
Figure 5: Thermal Expansion
These kits all work well ‘out of the box’, but there’s still plenty of adjustment for you to set things your way. You like stiff and reactive? Or soft and forgiving? It’s all there. Too much low speed rebound damping can have an adverse effect on grip, so the easily accessible adjuster at the base of the Öhlins units allows small, but positive increments of fine tuning, so you can take into account every single parameter. Sounds complicated? Nothing could be further for the truth. Just a few clicks either way from our factory settings will soon have your car responding precisely to your inputs and driving style.
The Road & Track McPherson struts also feature camber adjustable upper and lower mounts to give you the possibility to fine tune your wheels for the right occasion – whether you want to go for a ride in your neighborhood or take your car for a spin at the track on a weekend.
![](https://www.gmpperformance.com/CFJFiles/GMP/25803_t.jpg)
About Ohlins
Perfection in performance. That has been the Öhlins way since 1976. We have achieved this through an obsession with detail and quality. Every part of the Öhlins manufacturing process sets new standards for the automotive industry. Whether it’s material choice, design, manufacture or even a small detail like packaging. Only when it is perfect can it leave the factory. Our new R&T range finally puts Öhlins incredibly high standards of research, development and manufacture within the reach of the discerning enthusiast. This range is pure Öhlins, but the good news is – you won’t need a race team budget to afford it!
For us, the relationship with our customers is usually a long and fruitful one. We have supplied many of the top teams in motorsport, but also thousands of genuine enthusiasts. We only manufacture to one quality and every new client is as important as the last. In our view, the relationship doesn’t end with that initial sale. We see our role as providing support and back up thereafter, for as long as our client needs it. That’s way all Öhlins units are fully serviceable and adjustable, making sure that they give faithful and dynamic service for years to come. Our fully trained and approved service centers can make your old Öhlins units perform like new and even make changes in damper characteristics to suit your set-up preferences. Remember that our road and track range was born out of our Motorsport programme, where the impossible has to be made possible, so you can expect the same level of care and attention to detail on the R&T range.
The choice of materials used is one of the key factors behind Öhlins success. Each component is surface treated to ensure reduced friction and superior performance. The piston shaft and damper walls are micro-finished and plateau honed for optimum lubricity and low friction coefficient. This attention to detail is the same across the entire range of Öhlins products. Without this fine surface finishing, excessive friction can reduce the compliancy of the damper causing a loss of function.
Damping rate on the R&T units is fully adjustable and ties compression and rebound together as a matched setting, meaning that in 99% of cases, the units will work superbly, straight ‘out of the box’ with only the smallest adjustments required to suit the car or drivers individual preferences. Despite what other suspension manufacturers may tell you, comfort is king, even when you are trying to set-up a competition machine. Our vast experience on events like the World Rally Championship and Isle of Man TT races has shown us that the fastest drivers and riders are those that aren’t being shaken to bits as they go flat out. The ‘science of compliance’ is a hugely important part of our design work.
And last but not least, is durability. But hey, we’re Swedish, so chances are you have already guessed that we’re used to building components that survive one of the toughest environments in the World. The carbon steels bodies are salt spray tested and can service 240 hours of abuse, whilst still retaining function. Don’t let those stunning race car looks fool you. These are real-world units for daily driven cars.
![](http://www.roadandtrackbyohlins.com/wp-content/uploads/2009/06/ohlins_hq_exterior_02-590x225.jpg)
The Upplands Väsby Office
![](http://www.roadandtrackbyohlins.com/wp-content/uploads/2009/06/Ohlins_002_Nurburgring-590x299.jpg)
Distribution & Technical Centre at Nürburgring
No worries, we linked the picture to the item on our site so if you click on it, it takes you right to it. We do it that way so that the pricing stays as current as possible. So on this item, we are offering an introductory price to get some sets out there. Once the intro period is over, we will change the price on our site back to MAP.
$2900 each, as in, for one strut? How can a strut have camber adjustment top and bottom? And just to be clear, you adjust height by unweighting the strut body and adjusting the depth it is held within the carrier, correct? What is the range of height adjustment reduction over a stock 997 strut? Obviously, everyone is going to compare these to Bilstein PSS10s, at roughly 1/4 the price and a lifetime warranty. I'm just trying to make sure I understand if I, well, understand correctly.
Front
McPherson Strut
Dustcovers
Rear
Dustcovers
However, then I read down farther and found it buried in the lower portion where it talks about valving. This is a general overview of the Ohlins kits and directly refers to kits that are supplied with upper mounts, which doesn't apply to this particular kit. We will have the corrections made. Good eye and our apologies if it caused any confusion.
Regarding the range of adjustment, most coilovers can lower the cars way more than the valving can handle. There is approx. 3-4" of threading to slam it if you want but in my experience, you should not lower a suspension much more than 1.5-2.0" before the geometry is dramatically affected.
