Confused: Do I need to bleed the Clutch when doing a brake bleed - or is it optional?
Old 07-20-2012, 01:06 PM
PasPar2
PasPar2's Avatar
Default Confused: Do I need to bleed the Clutch when doing a brake bleed - or is it optional?
2007 c2s. Pedal might be softer then it should be as compared to my previous 996c2 (might also be in my head). I want to try to bleed some fluid out of the calipers - I did this on my 996 and it was simple but it was also a tip. Bleeding the clutch makes this a non DIY for me...
So: can I just bleed the calipers like I did after a DE day and ignore the clutch or is the clutch bleed a must?
I read here that bleeding the clutch is simple but I dont have the self confidence required to go that far... I am ok with caliper bleeding using a motive but not much more
thanks
Old 07-20-2012, 01:13 PM
San Rensho
San Rensho's Avatar
You don't have to bleed the clutch, but its highly recommended that you do. If you decide not to bleed the clutch, don't touch the clutch pedal while you are bleeding the brakes. Brakes and clutch share the same reservoir and when bleeding the brakes, the level in the reservoir may go down to the point that if you use the clutch, it will introduce air into the clutch hydraulics.
Old 07-20-2012, 01:28 PM
Chaos
Chaos's Avatar
Get a mitive power bleeder. Clutches are tricky
Old 07-20-2012, 01:34 PM
Chaos
Chaos's Avatar
Motive
Old 07-20-2012, 01:38 PM
PasPar2
PasPar2's Avatar
I always bleed using a motive... My son is still too young to help out
Old 07-20-2012, 01:44 PM
Spokane5150
Spokane5150's Avatar
It's a good idea to freshen up this fluid. Do a search. Someone did a good write up on this.
Old 07-21-2012, 12:14 AM
Edgy01
Poseur
Edgy01's Avatar
It's a little hard to get to but should be done just to clear 100% of the lines. If you have access to a lift--use it! Remove one of the body closure panels and then do some stretching to access it.
Old 07-21-2012, 12:26 AM
USMC_DS1
USMC_DS1's Avatar
Thanks Dan. Nice photos... been meaning to do this.
Old 07-21-2012, 12:32 AM
LC MotorSports
Former Vendor
LC MotorSports's Avatar
You should bleed/flush the clutch at least once every season.
Old 07-21-2012, 01:25 AM
PasPar2
PasPar2's Avatar
what is the procedure ? thanks.
Old 07-21-2012, 05:53 PM
kkswow12
kkswow12's Avatar
is it possible there are different tips on the clutch bleed opening? i just did mine and the tip stuck straight up with a plastic cap on it...
Old 07-21-2012, 08:19 PM
LC MotorSports
Former Vendor
You have a different style on the 997.2 transmission
Old 07-21-2012, 11:29 PM
Edgy01
Poseur
Edgy01's Avatar
997.2 is entirely different
Old 07-21-2012, 11:34 PM
LC MotorSports
Former Vendor
Old 07-22-2012, 03:29 AM
kkswow12
kkswow12's Avatar
mine is a .1 a 2008 build though, could it be?
Quick Reply: Confused: Do I need to bleed the Clutch when doing a brake bleed - or is it optional?
