Misfiring codes...
John
Bosch Digital Motor Electronics Motronic 7.8.1
Module Identification
Part Number 997.618.624.09
Supplier Part Number 00419100A842
Current Fault Codes
P0300Misfiring checksum errorFreeze Frame Information Fault symptom implausible
Self test not complete
Fault status fault not present
Warning light off
Fault path num 41472
FLC/HLC state 00
Fault check state 08
FCM line status 00
FCM output data (mil, svs) 88
Error Path Status 512
Counter Continuous Error 0
Counter Accumulated Error 512
MIL on counter 2
MIL off counter 3
Clear counter 4
Frequency counter 1
Calculated LOAD value 29 %
Engine coolant temperature 33 °C
Short Term Fuel Trim - Bank 1 0 %
Long Term Fuel Trim - Bank 1 -3 %
Short Term Fuel Trim - Bank 2 0 %
Long Term Fuel Trim - Bank 2 -5 %
Vehicle speed sensor 29 km/h
Ignition Timing Advance for #1 Cylinder 18 °
Intake Air Temperature 31 °C
Absolute Throttle Position 13 %
Commanded Secondary Air Status 04
Commanded Evaporative Purge 0 %
Barometric Pressure 970 kPa
Relative Throttle Position 2 %
Ambient air temperature 30 °C
Absolute Throttle Position B 12 %
Commanded Throttle Actuator Control 3 %
Long term secondary oxygen sensor fuel trim - Bank 1 0 %
Long term secondary oxygen sensor fuel trim - Bank 2 0 %
Fuel system 1 status 0980
Engine RPM 704 rpm
Air Flow Rate from Mass Air Flow Sensor 5 g/s
Absolute Load Value 44 %
Total operating time (first occurrence) 1439.3 h
Total mileage (first occurrence) 50424 km
P0301Misfiring cylinder 1Freeze Frame Information Fault symptom implausible
Warning light off
Fault path num 41728
FLC/HLC state 00
FCM line status 00
MIL on counter 2
MIL off counter 3
Clear counter 4
Frequency counter 1
Calculated LOAD value 96 %
Engine coolant temperature 36 °C
Long Term Fuel Trim - Bank 1 0 %
Short Term Fuel Trim - Bank 2 -1 %
Long Term Fuel Trim - Bank 2 -1 %
Vehicle speed sensor 103 km/h
Ignition Timing Advance for #1 Cylinder 21 °
Intake Air Temperature 30 °C
Absolute Throttle Position 60 %
Relative Throttle Position 49 %
Ambient air temperature 29 °C
Absolute Throttle Position B 59 %
Commanded Throttle Actuator Control 65 %
Fuel system 1 status A880
Engine RPM 4544 rpm
Air Flow Rate from Mass Air Flow Sensor 168 g/s
Absolute Load Value 83 %
Total operating time (first occurrence) 1458.7 h
P0302Misfiring cylinder 2Freeze Frame Information Fault symptom implausible
Warning light off
Fault path num 42240
FLC/HLC state 00
FCM line status 00
MIL on counter 2
MIL off counter 3
Clear counter 4
Frequency counter 1
Engine RPM 4544 rpm
P0303Misfiring cylinder 3Freeze Frame Information Fault symptom implausible
Warning light off
Fault path num 42752
FLC/HLC state 00
FCM line status 00
MIL on counter 2
MIL off counter 3
Clear counter 4
Frequency counter 1
Engine RPM 4544 rpm
Jka
