DIY Preventative Maintenance: 997.1S Water Pump Replacement - Part 1
Old 07-11-2012, 02:15 PM
IslandS52
IslandS52's Avatar
Re:step 6, Why did you cut the new gasket? That's unclear to me.
Thanks for the great write up!
Old 07-11-2012, 02:26 PM
USMC_DS1
USMC_DS1's Avatar
The gasket has two parts(one for WP and the other I suspect for the 996 thermostat housing) which are connect by three tabs... remember when we built model cars/planes and had to snip individual parts off the mold. Very similar here. Of course, I assumed the other gasket would fit my 997.1 but that's not the case. You need to order a separate thermostat housing gasket for the 997.1 specifically.
Old 07-12-2012, 01:30 PM
sullivas
sullivas's Avatar
Great post, thanks!
Old 07-14-2012, 10:50 PM
Musclehedz101
Musclehedz101's Avatar
Fantastic Write up!! Thank you for taking the time to do the write up for all of us. As someone that does their own "basic" maintenance, these write-ups are invaluable.
Old 07-15-2012, 02:38 AM
USMC_DS1
USMC_DS1's Avatar
Thanks. Glad to pay it forward... I have benefited from many a DIYs other members have posted. BTW, one more thing of note. If you open the Expansion Tank Cap another gallon of coolant will dump out so be prepared to have a total of 3.5 gallons of coolant on hand to fill back up if you do this. Again, the Airlift tools was great to test out my handy work for any leaks and easily refilled the system. I always burp the system afterwards but it really has not been necessary due to how well the Airlift tool fills up all the lines.
Old 07-15-2012, 12:12 PM
aaks38
aaks38's Avatar
Thanks for sharing this.
Old 07-18-2012, 03:50 PM
USMC_DS1
USMC_DS1's Avatar
Default Word Doc and PDF Version
Originally Posted by Spokane5150
Any way that you can save all this to a file for download? Maybe a word Document with the Youtube link. I'd like to add it to my personal collection of DIY's.
Spokane, Musclehedz101 create a word doc and I've create a PDF version. Both files are too large to upload on the forum so PM either of us with your email address if you'd like a copy.
Just one note... the wiring I referenced in the DIY are for the oxygen sensors. Two per side(one blk and one blue). Obviously very important that those wires are moved so that they are not stressed when the engine carrier bracket is moved.
Old 07-19-2012, 07:05 PM
Musclehedz101
For anyone that wants to download as a document of USMC_DS1's write up, here are the links:
MS Word Formatted Version:
https://dl.dropbox.com/u/82906075/Wa...placement.docx
PDF Formatted Version:
https://dl.dropbox.com/u/82906075/Wa...eplacement.pdf
Old 07-19-2012, 08:32 PM
Spokane5150
Spokane5150's Avatar
Perfect...thanks guys. That dropbox is pretty cool.
Old 07-20-2012, 07:08 AM
McCulla
McCulla's Avatar
I just went through the PDF, man that's a great write up/pic summary. Thanks!!
Old 07-21-2012, 03:04 AM
USMC_DS1
USMC_DS1's Avatar
Musclehedz101, thanks for posting the docs online. BTW, I registered for an account with dropbox as well. Great internet tool.
Old 07-21-2012, 09:27 AM
Doug_B_928
Doug_B_928's Avatar
Excellent work, thanks so much for taking the time to do this. I plan on tackling this in the next few months and will use your write-up as a guide.
Old 07-21-2012, 10:24 AM
Zeus993
Zeus993's Avatar
Received 1,267 Likes on 585 Posts
Really great write up. I also watched the video. Good quality footage. Makes it look doable with a handful of simple tools and a floor jack. Love the cameo of the dog at the end!
Old 07-21-2012, 04:01 PM
Spoddle
Spoddle's Avatar
Great write up, I'll be tackling this shortly along with replacement of plugs and the s-belt.
Old 07-21-2012, 04:27 PM
USMC_DS1
USMC_DS1's Avatar
Here's an index of DIY's... includes links for the plugs and s-belt.
Quick Reply: DIY Preventative Maintenance: 997.1S Water Pump Replacement - Part 1
