corroded brakes
my '97 carrera s with 17 K miles just required new rotors and pads due to corrosion (not wear). Porsche of NA refused to cover this $2000 bill
I use the car year round, even in the winters
has anybody else had a similar problem?
What is corroded rotors? Never heard of this and I've been working on brakes for a long time.
Also you can purchase new rotors and pads from the dealer for $1000 easy and Channing these parts take an hour working slowly and dealer hour rate is probably around $100....$2k...wow you got ripped off big time!
I've seen reports of heavily corroded rotors -- the inside surfaces -- to the point the rotor metal is flaking off.
I can't help but think there is a metallurgical problem (explanation) for this extreme corrosion. I have seen new/used cars parked up for months with no more rust build up that can be easily removed with a couple of hard braking events provided -- this is *important*! -- the car is not brought to a stop until after a few of these are done -- with no problems.
But IIRC in every case Porsche refused to cover the rotors under warranty.
Sincerely,
Macster.
Believe it or not this is a real problem for Porsches in the UK.
Sincerely,
Macster.
Sincerely,
Macster.
You were lucky to get that. In some cases it looked to me the owner had a legitimate warranty claim but I think I can count on the thumb of one hand the number of times any warranty claim was successful.
Sincerely,
Macster.
Sincerely,
Macster.
Where do you live? Are the roads salted during the winter? Coastal location perhaps? I power wash my rotors every so often to get brake dust out of the rotors but I wonder if that might help in your case as well if salt is a factor. If you have some mechanical skills... changing the brakes and rotors yourself on these cars is straight forward and would save you some $$$ if this is a recurring environmental issue.
Snowy slush with salt and grit would pack up in the wheel wells.
When I parked the car up at night in an inside but unheated garage the heat of the car would melt this and drip salt water on the wheels and brake hardware.
Because I was aware of this I would sometimes leave the car outside to limit the melt of this nasty slushy/ice or visit a car wash near the house and use the rinse setting of the wand -- the rinse water was heated some -- to melt this snow/salty slush away and give the wheels/brakes a good rinsing.
The brakes stayed corrosion free the several winters I spent in that area.
Sincerely,
Macster.
From: Bellevue, WA; '26 MacanGTS, '18 Macan S, '10 997S, SPASM, 6spd
May sound like a strange question, but what is your car wash routine?
Do you wash it, drive it into the garage and let it sit?
Or, do you wash it, then drive it sufficiently to dry off the brakes, then park it?
If the former, I've found that greatly contributes to brake corrosion; including parking-brake issues.
