K40 install?
So have determined that the radar detector in my 2005 997S is a K40 2000. I've located the front sensor (duh! Behind the front plate on the air dam insert), but have no idea where the rear sensor is installed. I am assuming it is behind the rear bumper cover. Can anyone comment on where rear sensors are normally installed? Need to find it because there's a fault (constant "tink tink" every 10 seconds or so) and am hoping it's just a loose connection to the rear sensor. Also, besides the volume controller, is there anything installed under the dash, and is, where? Trying to diagnose this myself in case its a simple fix. Thanks for the help.
Official Rennlist Snake Slayer
I had an 06S with K40 front and rear radar detection. I did not install it, and my guess is the vary a bit from installer to installer. I think there is a general system schematic on caliber's website.
My rear sensor was adjacent to the rear license plate, and the control module was up under the dash, on the passenger side.
Sorry I can't give you more specific info, as I didn't have any trouble with mine, and never messed with it.
Good luck and hope this was helpful.
