Where in Los Angeles...
... Is there a good tuner to do exterior mods like installing GT3 mesh in a GTS front bumper and other slight body modifications? Also, Anyone have a recco for a good tuning shop to instal RS flywheel? Any experience with how Porsche factory warranties feel about a flywheel mod? Much obliged.
David:
GT3 grilles won't fit in your GTS. Rennline, among others, makes a set that does - I have them in my GTS (a PDK) as does a friend of mine with a 6-spd GTS. I had mine installed by Craig at Walter's. As to the flywheel question, I'd call Justin, the service manager at Walter's. I've worked with him extensively, having owned 4 different Porsches that I bought there and he'll give you the straight story.
DMoore
'11 GTS
'10 Panamera 4S
DMoore
'11 GTS
'10 Panamera 4S
Thanks a bunch. Interestingly, I bought the GTS from Walter's. Tim Churchill and John Beech were terrific to work with. I could use the ride for fun & break in miles to and fro Santa Monica. I did see the Rennline set and the video and it seems to be the most sorted set. My 6 speed would also require the addl' center adapter to make it work. It is a much better look with practical protection for the radiators. It's also hard not to consider their RS door pull kit - a great throwback and I'm a sucker for classic notes on modern vehicles, especially the GTS, which is slammin'. I had a '06 Mex blue 4S and a '07 GT3 RS and the GTS is truly a hybrid of the two. Thanks again for the leads. DW
Hi David,
I had House Automotive (Pasadena) install my Rennline mesh grills, they are an indy shop but did a good job. The tech is an Ex-Dealer service tech and is fully Porsche certified. I'm actually taking my GTS for its first oil change there this Sat.
I used to live in Brentwood too! nice area and great restaurants that I used to walk to...
Best!
Best!
