Autocross
Old May 24, 2012 | 12:11 AM
LewisB's Avatar
LewisB
Default Autocross
What do you folks think of Autocross? Yes? No? Risks? Preparations? Pray tell!
Old May 24, 2012 | 12:23 AM
pilfjd's Avatar
pilfjd
I've always wanted to try it. Go for it and let us know how it is. :-)
Old May 24, 2012 | 12:57 AM
Hella-Buggin''s Avatar
Hella-Buggin'
I've done it a few times and just signed up for a local PCA autocross school even next month.
It's fun. A quick 45 second adrenalin rush. Learn car control at low speeds in a safe place.
Old May 24, 2012 | 03:05 AM
Mike in CA's Avatar
Mike in CA
25 Year Member
Absolutely, yes! Risk is low, fun factor is high, great way to learn about and excercise car control. Can be as easy going or as competitive as you want. Autoxers run the gamut from folks who show up in completely stock cars on street tires to those with all out racers that are trailered in. As a first timer, a car in good mechanical condition, a couple of extra pounds of air in your tires, and a helmet (loaners are usually available) are all you will need. Instructors are there to ride along and give tips. Check the web site of your local PCA chapter for additional information . All of the regions in the Bay Area do autocross; Redwood Region, where I am, has a particularly nice site at the Sonoma County Airport. If you own a Porsche, or are a PCA member, you're welcome. Do it!
Old May 24, 2012 | 05:01 AM
DreamCarrera's Avatar
DreamCarrera
+1 Great advice here IMHO.
I do AX to learn car control, not to bring home a trophy. I use the event to push the car hard under controlled(and legal) conditions. I intentionally get the car to understeer/oversteer to practice correcting/handling those situations. For me, it's all about practicing car control. I couldn't care less about my times(although it does sometimes hurt placing at the lower end of the field LOL).
Give it a try. If you don't like it, so be it, then you'll know and your car will be no worse for the "little" wear. But do beware, you may very well become addicted!!!
Old May 24, 2012 | 09:14 AM
GolfTango3's Avatar
GolfTango3
Autocross is fun until you start doing DE events.
After that, you realize that it's standing around in a hot parking lot all day to drive your car fast for 3 minutes.
Old May 24, 2012 | 09:52 AM
Spiffyjiff's Avatar
Spiffyjiff
autox is low low risk and i agree, pretty fun...
Originally Posted by bobbybailey
...until you start doing DE events.
autox is like boxing, but DE is like ballet - smoother, more controlled, and def more fun.
no matter which you decide to try, be careful...it's a slippery slope. you've been warned.
Old May 24, 2012 | 01:17 PM
utkinpol's Avatar
utkinpol
AX and DE do not exclude each other. Top AX dogs in SCCA are all racers. It is fun and much more mental than a DE at advanced stages.
Try it and see if you get hooked. Both DE an AX require a lot of free time from you to spend, that is true. None are very family friendly. It is a biggest issue for me.
7 Porsche Models That Have Aged Like Fine Wine
Old May 24, 2012 | 01:33 PM
Targa Tim's Avatar
Targa Tim
+1, exactly my thoughts.
Spend all day standing around. Actual driving time is less than 7 minutes if you're lucky. Done it once and never again.
Track days only for me.
Old May 24, 2012 | 01:55 PM
Mike in CA's Avatar
Mike in CA
25 Year Member
Very true.
As utkinpol says, the two are not mutally exclusive. I may be jumping to conclusions but it sounded like the OP had little track experience of any kind. Autox is a low risk, low cost excercise, (at the start at least) and can give someone valuable experience as well as a taste of whether they want to move on and include other track type events.
Old May 24, 2012 | 02:21 PM
AP997S's Avatar
AP997S
Big difference between track vs. AX events. Other than tires and ego AX is relatively safe and inexpensive. Being beaten badly by a 914 or Boxster is unsettling but they're in the 'family' so kudos to them. Unless you're fortunate to live close by a track they take a bit of planning and time. On the other hand AX events are typically close by and don't need a lot of prep and equipment to compete.
Old May 24, 2012 | 03:20 PM
GolfTango3's Avatar
GolfTango3
You're also going to get beaten by a kid in a Civic.
Old May 24, 2012 | 03:28 PM
AP997S's Avatar
AP997S
Been there done that. I once saw a guy driving a old Ford Police Interceptor that was posting times close to hotshot AX cars. The way he 'manhandled' that beast was awesome.
Old May 24, 2012 | 03:55 PM
cannon1000's Avatar
cannon1000
Yes. There is an Autocross thread you should read.
Prep. None. You can borrow a helmet usually or go buy one. That is it at a minimum.
Recommendation:
Helmet and comfortable shoes. Pants usually required...check local rules.
Food and lots of water, a chair, a container to put stuff in. Sunblock if summer time. Hat and sunglasses. Video camera to impress your friends :-)
Torque Wrench w/socket for lug nuts, Pressure Gauge, Air Pump. << Can borrow these usually.
I have done them and they are a lot of fun. It's a good place to safely learn the limits of your car and what it feels like when you cross it. Also good to feel how the car behaves with and without PSM on.
I think it is also good prep before starting DE's - if you want to do those. I think your learning curve will be much better if you do. As some say - you may start to enjoy the 2 hours of driving on a track more enjoyable than 5 or 6 one minute runs (and working). They are very different from each other.
AutoX is easy to get to know people if you are new. DE's are a lot more spread out.
AutoX is low risk. DE's are higher risk (Normal insurance does not cover)
AutoX is competitive. DE's you compete w/yourself
AutoX is relatively slow. DE's can be very fast.
AutoX can be very cheap. DE's can be moderately to very expensive (depending on how hooked you get).
AutoX you work more than you drive. DE you only drive and baby your car.
AutoX is fun. DE is VERY fun.
Some people are happy to just do AutoX. They don't want to deal with the cost and prep involved in DE's.
Some people, like me, move on and start doing just DE's.
Some people will continue to do both.
I am not sure I will do many more AutoX because once the DE season starts, there is a LOT of track events between all the different clubs. The AutoX seems to fall on weekends immediately before or after an event and it is inconvenient.
I have plenty of videos of both: http://youtube.com/soaringpil8
Old May 24, 2012 | 04:11 PM
Mike in CA's Avatar
Mike in CA
25 Year Member
Recommendation:
Good analysis. The point I think people should take away is that there's a lot more fun to be had driving your Porsche if you go somewhere and safely learn what it can really do....
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
