Why do some 997s feel notchy when shifting and some do not?
I test drove a few different 997.1s (08 C4, 07 C2S, 06 C2) before I bought my 06. One thing I noticed is that some of them had very notchy shift feel and some did not. None of them reportedly had the short shifter option. What would explain this difference?
My understanding from reading an earlier thead about transmissions is that they all have the same transmission or at least they are all manufactured by the same Japanese company.
Jason
Jason
I find that my car 2007, 911 shifts a little harder with more friction when it is cold. Once the car is at operating temperature it shifts much more smoothly. Was the feeling consistent throughout the drive?
Jason
Humm... maybe it had an aftermarket short shifter installed. I liked the more precise shift feel better than my 06. Maybe I'll give the short shift a try. Any reason you went for the B&M vs. Porsche OEM?
My p-dealer SR whom I really trust(was a former p-car mech) recommended the B&M SSK. Said it was like a bolt action on a rifle. I bought it the next day from Eric at bumperplugs. BTW, some on the forum really like the Porsche kit and find the B&M a little too notchy. It likely has to do with personal preference. For me precise, crisp, and smooth would be ideal. The p-kit is a direct drop in and likely easier to install. The B&M kit requires more install interventions but is tunable. I figure a bit of tuning and possibly some smithing on my part will get it just right for my liking.
Recently added the OE SSK....love it. Big diff from stock, however as reported is sometimes difficult to get into 1st/2nd when cold....I can get out of my condo....but if I hit the traffic light around the corner...it gets embarrassing...as if I don't know how to drive.
I am the proud owner of a notchy shifting 997. I have researched this extensively. It seems that the 997 is known as a sublime shifting machine to many, and then others have this notchy thing going on. No explanation. A little maddening. Have just had to get used to it.
I believe it is a function of these things:
(1) Temperature
(2) Short shifter (or not)
(3) Experience with Porsches
I learned a long time ago never to force a Porsche's gears, and should it appear to be fighting you, simply slow down, and go to another gear first that is easier to engage, and then (foot still on the clutch) select the gear you ultimately wanted.
Many drivers have a tendency to drive these things like Chevys and the end result is chewing up synchros.
(1) Temperature
It's all in how you drive it. It requires shifting at certain speed and RPM. Also, the veloscity at which you get to certain gears. It's hard to explain, but those of you who have had multiple Porsches know what I'm talking about. It requires some effort to do it right, but I personally like the quest for the perfect shift. It requires envolvement on the driver. That is why I would never want a PDK car.
