PDK creeps at idle?
Yesterday I bought my first Porsche, a 2009 C4S with PDK/Chrono. Aside from me asking her to marry me - This is one amazing car, correction, this is not a car, this is an amazing machine, a finely engineered work of art - I love it!!!
However, I did notice something that concerned me. In my driveway, which has a slight up-cline towards garage, I took my foot off the brake and the car started rolling back, not a little roll back until clutch engaged, but a lot. I gave a little gas and it still was rolling back. I thought I had hit the stick into neutral, which I didn't. It seemed as though the clutch would not engage unless I gave more gas. My immediate thought was I just lost my transmission or clutch. Is this normal. I ask in this thread, because this sounds like if these 997.2 PDK cars are designed to creep, then I have a problem. Want to make sure I don't have any major issues, while car is still under warranty for a few more months..
If I am hijacking this thread, let me know and I will start a new topic.
Thanks, Jeff
Thanks, Jeff
Thanks, Jeff
Thanks, Jeff
Exactly , porsche 997.2 has hill assist. Maybe op is comparing to other autos where the car simply does not roll down on an incline when you release gas without braking. The car hangs without stepping on brakes. The porsche does not do this. It needs the brakes and hill assist only assist for a few seconds.
My newly purchased 2009 997.2 Carr S cab creeps in forward and reverse. I asked the dealer about it after my test ride and he gave much the same reason that is stated in the beginning of this post. The only thing I am sure of, is that I need to make sure this car is aimed in the correct direction when I nail the gas pedal, because it hauls *** compared to my GTS Pig and my trusty 964. It happens so fast and smoothly thru the PDK, it will fool you as to your speed. My old air cooled manual 911 is quick, but you are very aware of the car getting up to speed. I went to pass a semi on our trip home from TN with our new car. I punched the throttle and flew around the truck and almost ran into the back of another car further up the passing lane! Those extra 120 HP seemed like an extra 400 HP. My wife was laughing because she thought I knew what I was doing! Anyhow, 997.2's creep or crawl.
Being a wet clutch, I suspect, that there is extremely limited wear and nothing to be concerned about from a maintenance perspective. Motorcycles use a wet clutch and are intended to be slipped on a regular basis as a means of control at low speeds. Motorcycle clutches can last ages without replacement due to the wet clutch design.
