Need input for my exhaust decision
Old 04-12-2012, 11:58 PM
fc2s
fc2s's Avatar
Default Need input for my exhaust decision
I have an '06 C2S with Sport Chrono & PSE and I've been to 2 Indies to troubleshoot a rattling sound that appears to be coming out of the left side muffler.
One thought it was a broken clamp/bracket on the topside of the muffler and the other thought it was the muffler clips that were causing the rattling.
Since the muffler clip option would be the least expensive solution, I decided to give it a shot.... unfortunately, it did not resolve the problem.
Let's take a step back to describe the rattle...
It is an annoying metal rattle that is coming from the right side of the exhaust system. It is most prevalent in first and second gear in the 2k to 3.5k rpm range.
When I have the sport mode on and get in third gear and above the 3.5k rpm, I hear and enjoy that sweet sound of the PSE.
So it’s not the clips… is it the upper clamp/bracket or is it the baffles in the muffler/s?
If the PSE is toast, is this the right time to be looking at after market mufflers and if so, which one is a suitable replacement for the PSE and which one would you consider to be an upgrade?
Thank you for your help…
Old 04-13-2012, 12:12 AM
USMC_DS1
USMC_DS1's Avatar
May be a broken tailpipe. My PPI found a similar issue before I purchased the car. P-dealer replaced the tailpipe.
Old 04-13-2012, 02:10 AM
jcnesq
Miserable Old Bastard
jcnesq's Avatar
I had one of the PSE cans on my 05S replaced under warranty because of similar rattling sounds, which I am pretty sure were coming from something gone loose inside the can. If you're out of warranty, then going aftermarket is probably your best bet.
Old 04-13-2012, 07:19 AM
gota911
Newbies Hospitality Director
gota911's Avatar
My 996 had a rattle similar to what you described. The rattle was from one of the cats which had gone bad. Cats are warrantied for 8 years or 80,000 per DOT regulations.
Old 04-13-2012, 07:54 AM
mjsporsche
mjsporsche's Avatar
Originally Posted by gota911
My 996 had a rattle similar to what you described. The rattle was from one of the cats wjich had gone bad. Cats are warrantied for 8 years or 80,000 per DOT regulations.
+1
I have heard from others that the CATs can cause a rattling sound. Not sure how to check them other than have your Porsche dealer or Indy inspect.
Old 04-13-2012, 12:28 PM
Mbiondo
Mbiondo's Avatar
Tubi. Everything else is crap.
Old 04-13-2012, 12:36 PM
mjsporsche
mjsporsche's Avatar
Are you on salary or commission?
Old 04-14-2012, 01:01 AM
Edgy01
Poseur
Edgy01's Avatar
Does the rattle sound go away in time as the engine and exhaust system heats up?
Old 04-14-2012, 01:11 AM
82_930
82_930's Avatar
I had the same on my '01 C4, it ended up being that I was missing what looks like a round Brillo pad that is used to damped vibration on the exhaust mounts...
Did you ever change the mufflers? Mine were changed by the previous owner to Fabspeed and apparently, the last installer did not put this back on.
Old 04-14-2012, 04:53 AM
MICHAELWWW
MICHAELWWW's Avatar
997 posts! Looks like you are done!
Old 04-14-2012, 10:40 PM
fc2s
fc2s's Avatar
I hope it's not the muffler becasue if it is, I'll have no choice but to go aftermarket. P dealer quoted me $4K plus installation.
Downside of aftermarket is that I'll lose the option of turning the sport exhaust on/off.
Old 04-14-2012, 10:45 PM
fc2s
fc2s's Avatar
+1
Thanks.. I'm having it checked by my indy next week and if it turns out to be the cats, I'll be paying the dealer a visit.
Old 04-14-2012, 10:53 PM
Dilys95
7th Gear
Dilys95's Avatar
Old 04-16-2012, 11:01 AM
Jason Judd
Jason Judd's Avatar
You don't need to get the entire exhaust...just get the muffler, which is about $650.
Old 04-16-2012, 07:46 PM
fc2s
fc2s's Avatar
Jason, the local dealer quoted $4k for two sport mufflers.
Do you have a good source for sports mufflers?
If do need muffler/s does it make sense to consider used?
Thx
Quick Reply: Need input for my exhaust decision
