Positive Porsche Experiences vs. The Unfortunate!
2006 C2S
Only issue under the original warranty was replacement of some interior trim parts.
Currently have an extended warranty, only issue was the replacement of the cigarette lighter and I don't even smoke!
Knock on wood ...other than the above, absolutely zero issues. The car has been outstanding, still tight as a drum with no rattles or squeaks. At this point, I'm seriously doubting whether my extended warranty will pay for itself - which is a win for me either way, as I'll be thrilled to have my car continue to run faultless.
2006 - c2s
current miles - 13,600
1st major - coolant res cap - $34
2nd major - rubber grommet on washer res. - $5
Life on the ragged "edge" for me !
How many miles you drive annually is a big part of the "if you buy warranty" answer. The more miles you drive the more you're exposed to potential break downs. In my case the car sees low miles. Extended warr would most likely never pay off.
Phil
Phil
Not in MA anymore
C2 06 55k sorta.....
When new sun roof drain obstruction
Front struts replaced @ 50k
Nothing else...not even brakes
It is a great car.... Fingers crossed![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Matt
Matt
$350 Porsche Water Pump
$55 Belt
$40 Antifreeze
$6 Thermostat Gasket
$10 Water Pump Gasket
$80 Thermostat
~$541 parts
~$480 labor
Peanuts - when compared to an untimely pump failure.
2000 Boxster - 70,000 miles in 4 years. Had IMS seal replaced, top replaced for cracked rear window (at 51,000 miles under warranty), window regulator under warranty, and the crankcase ventilation thingy replaced under warranty, oxygen sensor replaced under warranty.
2005 996 Cab - 40,000 miles only problems were I hit a deer on the way to work one morning and I got rear ended by a teenage girl talking on her cell phone while stopped at a red light.
2008 997.1 - around 15,000 miles. No problems
2009 997.2 C2S Cab - 30,000 miles. Warranty work to replace HPFP (was working fine at the time) and repair of muffler brackets where there was a recall.
I've had more trouble with my Lexus LX 470 and 570 than with the Porsches.
hey red horse, whenever you're ready to sell your 2009 C2S Cab, lemme know!
is it a 6-spd?
For the mileage or lack of I plan on driving this car, it's probally not worth buying and extended warranty.
I have 19K, max 5k per year, total after three more years, approx 35K, hopefully nothing major goes wrong between now and then. NK
That is a heck of a price. Do you know which warranty company and if your dealer would sell one to me?
I have a 2007 4S I just got. Debating the extended warranty also.
Thanks!
Thanks!
It seems that all we ever here from when it comes Porsche owner feedback is all the negatives from the unfortunate.
It would be nice to hear from those who have had minimal problems, but not necessarilly engine block / crack failures.
I ask this because I am considering purchasing an aftermarket warranty from my Porsche dealer 4 yrs 48K for $1600.00 which is a real bargain. I was quoted $2600.00 from two other Porsche dealers which tells me these warranty's are negotiable!!!!
Info requested:
Year: 2006
Model: Carrera S (997)
Current Mileage: 19550
1st Major Problem / Mileage: Rear Engine Seal @ 18500
Cost of Repair: $1200.00
Warranty or Living On The Edge!!!: "Edge"
Thx
NK
Info requested:
Year: 2006
Thx
NK
I disagree back
.. electronics although expensive, are within a cpl of thousands range, AND you can find cheaper parts to replace em with (not buying straight from dealer, eBay, etc), and labour on those items are managable.
The MAJOR cost are, IMS failure/engine failure/Transmission rebuild, ALL above $10-15K.
PS. btw, we got the EXACT same car!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
See attached pic -
My car has aftermarket tinted windows. They aren't very well done. The view out the back window at night is very distorted, there is a wrinkle in the passenger door, and the driver's door was coming loose at the bottom with the constant action of the window up/down when opening/closing the door. I also don't know if this tint level is legal in Chicago (bought the car in FL).
I'm either going to re-do it completely or remove. Curious what this color 997 looks like without tint or different levels of tint.
Either of you have pics to share?
(Called Porsche of Stratham on the warranty - waiting for a call back.)
2007 C2S Never a problem... factory warranty ran out last year. The car has never had a single expense beyond service when under warranty. I previously had a 99 C2 and when I sold it with 58,000 miles it never had an expense except normal maintenance and wear items. I do my own services and service often. I change oil before 5,000. Clean air filter, clean oil, clean gear oil, radiator full, fresh brake fluid.....what can go wrong. These are well made cars, why do we expect our Toyota to last forever and our 911 to blow up. Relax....enjoy the fruits of your labor. Worrying will not bring you luck.
