Whistling noise from engine????
SoCal
No real oil consumption or abnormal oil consumption at all just did 3650 KM from Edmonton to Montreal ( 2650 Miles ) oil an filter changed prior to the trip, oil level normal.
Hella
Will check oil fill cap and let you know.
Hella
Hi,
Were you able to get this fixed?
i have the same car and the same sound now.
The car has only 15K
Kouzman,
I just picked up a 2010 997.2 Coupe.
And changed the air filters on it, then noticed the whistling noise exactly as you described before finding and reading your post, and thought it was one of the filters that was not properly seated, so I reseated them, still have the whistle...Only when warmed up and at idle. Will check the water pump.
Pierre
Pierre
