Battery Clamp Replacement
I'm missing one of my battery clamps and have been searching without luck for a replacement. Other than the dealer does anyone have a source or recommendation? TIA
Don't know what you're asking - the hold down clamp (there's only one) or one of the cables or the plastic devices that hold down the plastic battery compartment cover??
Here is a shot of the clamp on the passenger side and what I thought was the missing driver side clamp (and a more interesting pic). I did visit Pelican Parts but could only find older vehicle clamps unless I just missed it - will double check. Thanks!
Also, you don't have the correct size battery. It's supposed to slide all the way to the right (driver's side) so that the lip on the battery fits under the lip on the tray. Then the one hold down clamp on the passenger side does it's job.
There are at least three mounting holes on the passenger side of the battery tray.
One for battery sizes:
48 - small, MTP-H7, intermediate size usually the one *Interstate has on the truck, and 49 - largest that fits also no threads so needs nut/bolt held from under bottom.
Some have a 4th mounting hole for a smaller size battery 46.
You should take the bolt out of your tray and slide the battery over so the ledge on the driver’s side is locked under the tray lip on the driver's side.
**While you are at it you should consider taking the battery tray out and washing it with a baking soda water mix. It looks like the battery may have been loose enough to jostle around and spill some acid, white residue in pics.
Battery sizes that fit =
H6 also called (48) or MTP-H6 640 800 121 85 10-15/16 x 6-7/8 x 7-1/5 Top
*H7 also called (94R) or MTP-H7 640 800 135 85 12-3/8 x 6-7/8 x 7-1/5 Top
H8 also called (49) or MTP-H8 720 900 176 85 13-15/16 x 6-7/8 x 7-1/5 Top"
**good call speedy Spokane
