Do all GTS cars have centerlock wheels?
The GTS is (was) available with only two wheel choices. The standard wheel is the RS Spyder Wheels with Center Locking. The only other wheel available is the Carrera Sport. The standard wheel color for both wheels is black. Silver is an option for either wheel, as is the "Painted in Exterior Color" option.
Check out the configurator. The GTS variants are still listed.
As standard, the 911 Carrera GTS models are fitted with 19-inch RS Spyder wheels with center spokes and rim well in a black painted finish.
The main feature of these forged aluminum alloy wheels is the central locking device – a clear reference to the world of motorsport. Compared with the conventional five-bolt wheel connection, it offers enhanced driving dynamics and performance thanks to the reduction in rotating masses.
Why? If you track your car and need to change wheels frequently, the CL's could be a pain. But for me and most others that don't frequently track their car, or maybe never track the car, the CLs are nice. They look good and make the GTS a little different than the regular Carrera. The CLs are also forged which is nice. I agree that they do not really provide a significant mechanical advantage over regular wheels, but I happen to like mine, as do many others.
There are some advantages to the CL wheels. They are forged and are lighter and stronger than other Porsche factory alloys. Also, given that a special tool and 444 ft/lbs of torque are required to remove them, they are unlikely to be stolen.
Paul,
I've got your car. 2011 GTS, 6 speed, GT Silver, full leather, 5 lug Carrera Sports in black, unfortunately it won't be for sale for awhile. I agonized over the wheel selection when I ordered the car. If the CL were of the "air gun removable" style (like Cup Cars), I would have jumped on them. I knew ease of removal would be an issue for me. I've had the wheels off/on at least 5 times in the past year (bleed brakes, tape wheel weights, detail inside of wheel, etc) and I have a set of CCW (in 18") coming this week with some dedicated AX rubber. No doubt you are correct that the 5 lug option is rare on the GTS. Good luck in your search.
Joe
Joe
You can probably switch over from center lock to 5 lug pretty easily if you can round up the parts. I believe you'll just need the "wheel carrier" part all around. Or if you can find someone with a widebody car they may want to trade you. A competent shop should be able to make the trade in about 4 hours of labor. I guess you'll both need an alignment after that.
I think you make his point - the reason for CLs is that they are supposed to be easier to change quickly - 1 bolt instead of 5 - hence their use in motorsports and the track-inspired GT models. But the reality is, for a street car they are more of a hassle, and all about vanity.
If you want OEM forged, get the turbo wheels.
if i will not find GTS in my specs before this season starts then most likely i will keep driving this '06 car until its end... not if it would be an end of the world, of course, it`s just a car, after all.
No. My point is that if you don't change the wheels often, or not at all for me until I need new tires, the CLs are not a pain. Sure, if you are always removing the wheels to change to winter tires, or track tires, the CLs would be a pain, but not so for street use with infrequent changes. I've had my GTS for 9 months and not needed to remove the wheels.
I guess my point is that It's all aesthetics.
The article lists the parts needed (GT3 conversion) as:
1. Two front wheel hubs ($326.80 each)
2. Two Front Wheel bearings ($88.70 each)
3. Two rear wheel hubs ($359.32 each)
4. Two Rear wheel bearings ($113.49 each)
5. Porsche Lug bolts - 20 @ 7.43 each = 148.60 or Apex Track Studs and steel nuts @ $168 total
