Question about Removing back seats
Hey guys.
I'm in the market for a 997 turbo and yesterday I went to test drive one for the first time.
Since I'm in a wheelchair I need it to make sure that I could comfortably drive the car and that my wheelchair could fit in the car... And that's where my question is coming from.... I would need to remove the top section of the back seats (the part that folds down) in order for me to comfortably get my chair back there.
Has anyone done this removal?.. I'm pretty sure you got to take alot of the interior apart but I wanted to know if it can be done.
It can be done very easily; I did it to install my harness bar. The key to removal is the center hinge pin between the seatbacks. Carefully pry off the plastic piece and loosen the set screw that retains the hinge pin. (Getting the plastic piece off without breaking the tiny retaining bits is the only tricky part. Some foam and double sided tape work fine to put the plastic back in place if you do break them.
) Now you can slide the center pin to one side and pull the seatbacks off the outboard pins. The brackets for the outboard pins can be unbolted and removed at this point if you want.
It's really pretty simple; no other interior trim needs to be removed.
+1 very easy and passengers can still sit in the back if need be. the carpet is almost as comfortable as a seat back though I wouldn't ask anyone but a smaller child to sit back there for any appreciable amount of time.
its the same deal as a gt2 or gt3. The seats are out and carpet with no holes goes in, plus the quarters have holes so they are replaced and the c pillars have no seat belt holes. If you buy those parts you can replacate it as a gt 2-3.
the carpet is a couple hundred, the quarters are expensive but you can recover them fairly cheap
Hey guys.
I asked my dealer about this when I ordered my GTS last April and he told me that this wasn't an option for U.S. destined cars. Considering the source, take that nugget for whatever it is worth.
I have a "TI" manual wheelchair that looks like this.
http://www.tilite.com/wchairs_zrs2.php
by taking out the top section of the backseats you should be able to fit in the wheelchair frame and wheels back there with no issue... hopefully this helps.
