NAV-TV Iphone 4S noise
So i just had my nav-tv unit installed and I am using an Iphone4S. Well to charge it Nav TV needs this little black power adapted for the 4s. Well when i use the adapter there is a slight noise... But no adapter and the noise is gone. Do others have a similar issue or is this just a bad adapter?
Thanks guys. It's not the ground as when I use the white iPhone cord it is clear. It is when I use the black power adapter needed to charge the iPhone 4s it a "whine"/ interference sound. Hitting the gas does not change the noise. Dan do you have the power adapter?
I'll do you one better. I went through two Nav-TVs that both eventually crapped out and stopped working. One faulty unit I chalk up to bad luck. Two - the product sucks. Ripped it out and redid the whole head unit and amp. Never looked back. Good luck.
