Valentine One "Savvy" 997.2 EASY install
I would also be interested in install pictures. For those that have run the wire, is wire thickness thin enough to easily fit into the gap near the windshield? This looks like a great solution for anyone wanting directional awareness while eliminating around town radar. Not as good as GPS but certainly it has its advantages.
install photos
From the drivers seat - and getting in and out of the car really you don't see any wires... If I stuff the camera right up to the dash "gap"you can see the wire. Since the wire is oval shaped it slides into the gaps very nicely. Getting in and out of the car you cannot see the Savvy in the footwell. Dan's idea of putting a couple of knots in the wire to make it thicker for the area by the windshield is probably a good idea... the gap at the windshield is much larger than the wire...although I have not yet had any problems with my wire falling out. Of course start at the unit and work your way towards the Savvy. That way you can just stuff the excess cord in the pocket in the footwell.
After driving around with the V1 for a couple of days I can say that I am very, very impressed. Not as many false alarms as I thought based on the reviews. The directional arrows help in identifying those set false alarms/triggers...for example on the one way home there is a spot on the fwy where it picks up some kind of radar door opener and it goes off as I approach, go by and then pass that location. And there is a sign that reads your speed right by my house which of course sets it off coming and going...but otherwise it is silent. If there are issues with falses (or if I lived in a big city) you can turn on a logic or advanced logic funtion that screens out what it thinks might be false alarms..
On a PCA club drive on this last Sat from SB to Jalama beach it made the drive so much more enjoyable...in fact the peace of mind/enjoyment from that one drive I got my money's worth!
The unit turns on and off with the car.
The A pillar to dash is easy - it stuffs completely into the gap there. The most visible spot is where I took a close up pic... but your really can't see unless your looking for it.
Poseur
Keep in mind that the gap is there for a reason. It's to absorb expansion and contraction of the two dissimilar materials. Once you fill the gap you will introduce future squeaks.
Newbies Hospitality Director
This is very similar to hard wiring your detector to the fuse box. Other than installing a piggy back jumper on a new fuse installed in position C1 (for a RWD car), there really isn't any difference in the installation procedures.
I'd be interested to know your V1 programming setup with the Savvy. After programming the V1, I get K band alerts below minimum speed yet I have all K shut off and min speed set to 25mph on the Savvy. Not getting alot of alerts, just surprised I get K at all. Will say this for the V1, I sure do get long distance warning alerts in Ka, and knowing the direction helps keep eyeball and head thrashing to a minimum.
I just got my Valentine 1 with savvy that let's me hook it up to the OBD port for power. 997.2
I turn on the car, plug in the port and after a few seconds the Valentine 1 powers up. When I turn the car off and go to turn the car back on I can't get the Valentine 1 to come back on. The only way to do it is to unplug the OBD and plug it back in...few seconds later on it goes.
Any help from people who have done this?
Hey Guys... I just installed the savvy in my 991, and the savy is so bulky, I can't close the fuse box cover, and it kinda sticks out...I'm afraid that I will kick it out with my left leg... anybody do any mods to fix it? I like the concept, but being concealed, I'm thinking of hardwiring it without savvy... just wanted to people's opinion.
