IMS Guardian
#61
Jake,
if we just would look at a magnetic oil plug - when i change oil it always has some layer of very thin 'paste' of magnetic dust from normal wear, any tracked car will have it. just from a visual perspective - is it possible to tell if ferro-magnetic particles come from IMS assembly specifically?
is it an overall 'safe' approach to assume it is a normal tear/wear as long as you have no 'chunks' or visible specs and all material on the magnet plug resembles thin metal dust? what are the guidelines there? what level of thickness of collected material should be considered a problem?
#62
Jake,
I know what our engines generate as we see them over and over at different times during development and testing, but thats not universally applicable to all the M series engines. The bigger the pieces the bigger the problem as a general consensus.
Also, the only magnetic drain plugs that we use are our MCDs from the IMSG and the LN Magnetic drain plug, which is the strongest available. Magnet strength and type will determine the material collected, so a person with a different plug than yours will have different amounts of material than you do, so thats a variable that keeps any blanket statements from occurring. The cheap magnetic drain plugs are less than 1/2 as strong as the 23# rare earth magnet of the LN unit. That makes a difference.
As I had stated before:
Mag drain plug inspection is better than nothing; but since it is entirely possible for an engine to progress threough all 4 stages of IMSB failure in one oil service interval it is simply not enough. The IMSG monitors ferro-magnetic material levels in the oil the entire time the engine is being operated.
#64
I just don't believe that you have to "quote" on their behalf because "they don't own a computer"?
Anyhow, your job is to generate sales for your products by getting people scated... BUT based on all discussions with local LN Engineering rep, and the head mechanic for Porsche dealer here (my friend), IMS issues are WAY OVERBLOWN, and basically do not exist on post 2005 cars. His recommendation is for older 2005 cars with earlier IMS, just upgrade the bearings when you do a clutch work and you're done! All of these other items are not proven, and as other posted may even cause issues with making the *guardian* the new weakest link!
#65
