Played with my new Durametric reader tonight
Couldn't reset steering angle sensor on mine either - 2010 997.2. Have pro version, it has a few bugs.
Couldn't save & back up config files successfully either, did successfully disable rear wing operation. That's why it's still a beta version of the software. Clears faults OK. Couldn't disable multi function steering wheel either.
Wow, for a hyper-expensive 'pro' version it doesn't seem to be able to do a whole lot. Its been in beta for ever it seems.. are they even working on it.
If I need a version that doesn't do a lot but clear codes, the basic version fits the bill fine. All I really want is to be able to specifically set the reminder interval to a particular value for mileage and time.
No solution for the multi function wheel, a very mechanical process for the files, so much so I haven't bothered. In actuality the Pro version is very primitive, better off not getting for most. I got it because I changed to a fixed rear wing & removed my multi function wheel. Thought it would provid me with flexibility when I wanted to change back to original config over going to the dealer (that's why saving the configs was of interest to me).
Talk to vivid/softronic it's a bit flakey I've found as well. Been in Beta for a long while.
What we need is a cable & software to get serious like they do with BMW's.
