Wheel/rim size
I have a 05 c2s cab My rear tires are 305 19. How do I know if the 305's are standard on this car. Need to replace tires but don't know weather to go with 295's or 305's.
I used to think that all C2S's came with 295's back then, but I once asked the dealer and they did say that some cars came with 305's. Not sure why they flip flopped back and forth but in both cases they kept the 235's up front.
Do you have OEM wheels? Which ones are they and what width? That may give you a clue at to what size tires were originally mounted. On the 997.2 Carreras like mine, 305's came with the wider 11.5" Carrera Sport Wheels and 295's with all the rest of the OEM wheels. Might have been different with the 997.1. If you don't know the wheel width, you should be able to find the stamping on a factory wheel that shows width and offset.
Did some research. Both the 295 and 305 tires both has the same rim size. 10.5-11.5. So Looks like I can use either one. As I mentioned I have 305 on the rear now. Comparing the two in price, there is an extra $150 a pair for the 305, from what I can find
Interesting. I guess Porsche must gone with both sizes on the 997.1 with 11's as, for my ''09 at least, only the 11.5" Carrera Sports came with 305's. In any event, we knew the OP's 11's could work with either tire so it's still just a matter of choice. Maybe he should check his door jamb to see what came stock on his car.
Poseur
Look inside your door jam. It will show you what tires came on your car.
When Porsche introduced the Carrera Sport wheel in MY06 they increased the size of the wheels by a half inch both in front and in the rear. That dictated a growth in tire size from 295 to 305.
There is hardly any difference between the two tire sizes.
