Indicated vs actual speed - observation
In case anybody is wondering, I had the opportunity to observe the indicated speed as shown by three sources: speedometer, OBD, and GPS. The OBD and GPS signals came from my Aim Solo DL.
OBD and GPS show the same speed value. The speedometer displays a higher value. The delta varies, but at 65 mph on the GPS and OBD, the speedometer shows 68.
The bottom line? The car has a more faithful measure of speed, but Porsche has chosen to not display it on the dash.
Porsche didn't choose this on their own. It's mandated by several government bodies. BMW is often off by a fixed offset and a variable amount than can total nearly 10%. Do a Google search and you can find more details. The bottom line is that governments want never want a driver using the speedometer to be over the posted limits.
Gary
Gary
My GT3 speedometer reads a constant 3 mph high from around 15 mph up to about 70 mph. However, above that the difference starts to grow and it's off by about 5 mph above 100 mph.
Poseur
Truly, Porsche knows how fast the car is going because the rear spoiler deploys at 75 mph--which is NOT 75 mph INDICATED. It's more like 77 and a little bit for my particular car. Personally, I'm sick of the government mandating stuff like this, because I have to mentally subtract 2 mph every time I look at the digital readout to know what I'm REALLY doing. Years ago, the DOT mandated a even larger speed delta (always speed optimistic).
All the discussion about regulations is interesting. I had never heard this. In fact, I considered my last car (a Corvette C6) "dead on." The digital reading was within 1/2 mile per hour of the analog readout (digital did not read in less than whole numbers so the speed jumped to the next number after 1/2), both of which matched the GPS, and all matched law enforcement radar. At 55, 65, and 75 MPH the numbers matched exactly. Maybe my measuring devices are all suspect.
Poseur
When I learned about this fudge factor I did some reading. Go look it up on the internet (the all knowing). DOT controls everything.
All Regulations
Part 393
< 393.81 393.83 >
Related Links
Disclaimer
Interpretation
Help
Subpart G - Miscellaneous parts and accessories
§ 393.82Speedometer.
Each bus, truck, and truck-tractor must be equipped with a speedometer indicating vehicle speed in miles per hour and/or kilometers per hour. The speedometer must be accurate to within plus or minus 8 km/hr (5 mph) at a speed of 80 km/hr (50 mph).
[70 FR 48054, Aug. 15, 2005]
All Regulations
Part 393
< 393.81 393.83 >
Related Links
Disclaimer
Interpretation
Help
Thats not about a supposed fudge-factor, that is about the required accuracy of the speedometer. All that reg says is that the speedometer needs to be within a certain tolerance at 50mph.
It just mandates the quality of the speedo be at least this good.
All Regulations
Part 393
< 393.81 393.83 >
Related Links
Disclaimer
Interpretation
Help
All Regulations
Part 393
< 393.81 393.83 >
Related Links
Disclaimer
Interpretation
Help
