Clutch issue-please advise
I was out yesterday with a group of car guys for some spirited driving around Hell, MI on a fall "To Hell and Back" driving tour. About half 2/3 of the way through the drive I started to notice my clutch pedal was hanging up on return when I lifted quickly. If shifting fast it would cause the clutch to slip minimally. This happened a couple times before I realized what was happening. The clutch return issue happens consistently however I drove home carefully so as not to burn up the clutch.
Has anybody heard of any issues caused from a faulty throw out bearing or the clutch spline hanging up instead of sliding smoothly on the transmission input shaft?
Also, I assume my car will be heading in for clutch work and plan on having the IMS retrofit done in addition to clutch disk, pressure plate, throwout bearing. Is there any other PM work that should be considered while getting the clutch done?
Thanks in advance for help and suggestions.
ADias, your thoughts on price are encouraging. I hope you are right.
I've been torn on the IMS fix as my car is a late 2005 and may have the 2006 version. I like that this forces my hand to get into it and make sure what I have is either of newer design or done right with upgrade.
OK, took my car in today. Technician believes the clutch system needed to be bled if not totally flushed. He said generally when you pay for the every two years brake fluid fluid flush the dealer does not also bleed the clutch system. This would have led to clutch pedal not returning to top of travel properly and therefore could have burnt the clutch a little.
Since my car is a 2005 it is always on my mind the potential for IMS failure. I opted to have the LNE bearing retrofit done, new RMS, new clutch disk, throw out bearing and new pressure plate. Since I never was able to detect the smell of burning clutch he said it is highly unlikely to have any flywheel damage.
So a couple days I should have my car back and ready to stuff into storage until Spring.
