Replacing a good tire?!
I have an 05 C2S. Now 17.5 K on the clock. I replaced the back OEM tires, Pirelli P Zeros at about 14K I think. The front tires still look great with a lot of wear, but now are about 6 yrs from mnftr date. Would you replace these just b/c of time? I am considering starting to do a few DE's, so go easy on the browbeating for not driving it hard enough. I am concerned they won't hold up under this strain.
Jim
Jim
Miserable Old Bastard
No expert but in 356 circles which I participate in (where tires may look almost new 10-20 years after manufacture) it seems to be the rule that after about 5 years, tires are degrading and may not be safe. So if you are planning DE's it might be a good idea to stay on the safe side and replace them.
Jim
Jim
The tipping point to change the tires out now I think arises from the fact you are considering participating in DE's which of course places a bigger strain on the tires. You do not want to find out the hard way the tires are not up to the task.
The other thing to consider is the front tires due to their age and usage will suffer more from the heat cycling and they're rate of degradation will be faster than the rear tires.
The front tires already have had 14K mile of this. My experience with Pirelli tires on my Boxster compared to other brands of tires (Michelin on the Boxster and Continental and Bridgestone on the Turbo) is the Pirelli tires appear to suffer more from heat cycling than other brands of tires. As a result the Pirelli tires get harder (and noisier) as a result given the same number of miles.
The harder tires grip less and you may find the car a bit of an odd handler because of this.
With both front and rear tires new when you enter the DE's the front and rear of the car are on equal footing, as it were.
Sincerely,
Macster.
Good thoughts, guys. Thank you. Its just so hard to pull the trigger on new ones when they look great from the sidewalls and tread, oh and they cost so much too. Oh well.
Jim
Jim
