Is IMS not if but when?
Is the IMS or the RMS leak a not if but when type problem? Is it bound to happen to every car at some point? I've got a 07 C2S with nearly 30k miles on it. I haven't had one problem with it. I've never even had to add oil to it in 5 years. Do I need to worry about IMS and RMS in the future?
Eh, hard to say. The bearing isn't a swap like on a 9x6 vehicle but they can still leak. I've seen the IMS seal leak and RMS. Just requires pulling the trans, clutch and flywheel if a manual. Tip and engine together then seperated to access it then. Pull RMS and IMS cover and replace.
Unless yours is leaking, I wouldn't worry. Just look ever so often.
I try not to worry about it, but with 70K miles on my 997, and reading this months article in Excellence magazine, it does rather sound like a when and not an if. I am just hoping the when is over 100,000 miles away...
I guess we'll beat this horse until all our cars have 100,000 mi and then we'll know.
5% of cars before '06. Read it, memorize it, repeat it.
Put it this way, not many people have IMS issues, less than 10% (from what I have read), majority of them are 05, since you have an 07', consider yourself lucky if you have IMS issues.
My advice is to follow a good oil/filter change schedule (I follow one of 5K miles) and use an approved oil and take care of other vital fluids/filters on time and just enjoy the car.
The odds are quite in your favor the RMS will *not* leak nor will the IMS fail.
Sincerely,
Macster.
i understand a RMS repair is about $1,500, IMS $500 - $600 more - if that is correct, that is about a set of tires, much less than a cool set of wheels -is it really worth fretting over?
you guys need to do a search and get the facts straight. lot of just wrong info in this thread and not just in this post.
Furthermore, the less than 10% figure (if even accurate) really applies to the 996 Carrera and 986 Boxster.
While not immune, the chance of a failure on a 997 is likely far lower than 10%. This is because Porsche upgraded the IMS bearing several times over the life of the 996 & 997. For example, a 997 '05 MY failure is far less likely compared to early model 996 cars. And it's very rare that an '06-'08 MY 997 failure is even reported on this site.
If you have '05 or early '06 cars, I would worry about it... '07/'08 is most reliable and have very very rarely had IMS issues.
