Mixing N1 and N2 Michelin Tires
I would not do it! You are sub optimizing on what has been engineered into the handling of the 997. If the fronts break away faster than the rears, you might be sorry for mixing the two tires. If you drive the car gently without pushing it, then your risk is low.
