WARNING-DIY Oil Change...
Old 09-28-2011, 05:58 PM
Minok
Minok's Avatar
Originally Posted by orttauq
I have one of these for changing the oil on my V10 Touareg and it gets 100% of the oil (13 qts)
Although it does NOT get all the oil from the 3.8 (since no dipstick tube) it gets most of it so when I do pull the plug I only have to deal with a few quarts.
Where are you feeding the extraction hose into to get most of the oil out (without removing the oil drain plug) ?
Old 09-28-2011, 06:31 PM
orttauq
orttauq's Avatar
Filler neck but it takes a bit of fishing. Still better than all that oil rushing out.
Old 09-28-2011, 06:52 PM
Edgy01
Poseur
Edgy01's Avatar
I have to laugh when I read this!
Years ago when we had a good 14 quarts of oil coming quickly out of the oil reservoir behind the right rear wheel we had quite a time dealing with it. 8 quarts is nothing! Adopt a large mouthed container, something like the size of a cut-down 5-gallon paint bucket, or something you would steam clams in!
Old 09-28-2011, 07:46 PM
Sane Asylum
Sane Asylum's Avatar
What he said......It only took once to figure that one out though..
Old 09-28-2011, 09:31 PM
orttauq
orttauq's Avatar
Yep...I served my time with a '76.
Bought it because 13 quarts of diesel oil ain't nothing to laugh at. Plus on the V10 the filter is on top so no need to even crawl underneath.
Hook up the extraction pump to power, fish the tube in as far as it will go, flip a switch, grab a drink (or do something else on the car).
While under the car changing the filter I have about 2-3 quarts to drain including the filter...no jacks, ramps, or huge tubs of oil to drain.
Old 09-28-2011, 09:40 PM
cvazquez
cvazquez's Avatar
Lessons learned.
Old 10-02-2011, 03:48 PM
dbrians
dbrians's Avatar
I have a 2009 C4S - am changing the oil right now. Don't torch me, I'm a new owner doing this for the 1st time....but I can't find the filter housing. Expected it to be adjacent to the oil pan. Where is it?
Old 10-02-2011, 05:55 PM
mdrobc1213
mdrobc1213's Avatar
In the new car I think they are changed from above...not the bottom as before next to the pan. Look to the right side above the air filter. Need a filter wrench or proper ratchet lug to open up the plastic cover then the oil filter is easily assessible.
Old 10-02-2011, 07:11 PM
vexed
vexed's Avatar
In the engine compartment right side. 36mm socket recommended.
Quick Reply: WARNING-DIY Oil Change...
