Carfax - Is this a red flag for a CPO 997?
Pulled the carfax on a 06 C2S. In one repair, this was done. The car only has 15K miles and the dealer is about to CPO it with my deposit.
Any ideas what this could have been for? Unfixable leak?
Thanks in advance.
Transmission removed to complete repair
Engine/powertrain computer/module checked
A/C and heating control assembly checked
Engine cleaned
Clutch release bearing replaced
Transmission checked
Thanks in advance.
Engine cleaned
IMO A clutch release bearing should not need to be replaced at 15k unless the car has been abused. If the car has been abused there is a greater chance that some other parts have been compromised. So... make sure you get a DME read out and make sure there is no longer any strange noise coming from the clutch and transmission.
CPO is a great safety net but check on the actual duration of the warranty, I am not sure if it 2 years from purchase or only 2 years from expiration of the original warranty, just a point to clarify.
As to the work - my experience was similar and worked out well for me. My car had a bit of work done to qualify it for CPO - with less than 24k on the clock and 6 mos remaining on original warranty. RMS seal, clutch pack and release bearing, new battery, brake fluid flush, etc. I also knew that the 4th gear synchro had some wear but only noticed if driven very, very aggressively - I had the dealer make note of that and then waited until I was over 40k miles to have a factory reman installed under CPO. Actually, my dealer performed quite a few repairs under CPO (including every squeak and rattle) for me and it has really made the difference in the value of the car - for me. The RMS they replaced was still bone dry when they replaced the trans, the engine is still bone dry and uses less than 1/2 qt of oil in 5k miles. Have never in four years added oil between changes - 68 k on the clock now. Of course I thought I'd be in a CPO 997 by now, but love this 996 and 997.2 should eventually get to prices I would be comfortable with.
How long did it sit at the dealership? My '08 had 46K but sat for 4-5 months on the lot. RMS seal dried out then leaked. My Indy PPI caught it... I had the p-dealer replace it before accepting delievery even though the car was under warranty and had a CPO after the warranty. Even if it's under CPO have an Indy do the PPI. You'll be surprised at what they'll find.
