oil drain pan
It seems like I'm changing the oil on the 911 every few weeks (i'm a high mileage driver). All of this oil changing has got me thinking about my oil drain pan which fills right up to the edge when i do the oil. I spill every time trying to slide it across the floor when full.
Looking for something that easily holds 9+ quarts, fits under the 911 without jacking, is easy to pour out, and rigid enough so it doesn't fold under the weight of the oil.
I was thinking about this but I thought I'd ask around and see if anyone had anything better?
http://www.jegs.com/i/Dorman-Product...ductId=1666566
thanks
thanks
I've had one for years called the Wedcopan and it's still being made. It's very low profile, holds 16 quarts, and has a pouring spout which is convenient for pouring into containers for curbside recycling. Click on the "PDF brochure" link on the web site. I can't have paid more than $10-15 for it. The Griotsgarage one looks very cool but $70 is pricey for an oil pan.
http://www.theplasticsgroup.net/consprod_drainp.htm
I been using this one for ten years & no splash problems with the Porsche:Blitz Oil Drain Pans - 15-qt. oil drain pan
http://www.walmart.com/ip/Blitz-Oil-...n-pan/15629411
This pan will fit under the car but even with a low profile pan you can use extra clearance to reach the drain plug while the pan is in place, especially on a car that's lowered with SPASM like mine. Check the pics to see how I get an extra 1 1/2" without jacking up the car.
http://www.amazon.com/Plastics-Group...ef=pd_sbs_sg_8
Poseur
Try what I've used for decades with 911s. (Especially useful on the air-cooled engines that hold about 15 quarts!)
Do you have an old 5-gallon plastic paint can around? Pick up one of those orange things from Home Depot if you don't. Pour about 10 quarts of water into it and see where that settles on the inside of it. Mark it with a scribe. Then see how high that is compared to the clearance height under the engine when it is not jacked up at all.
Cut the 5-gallon pail down to size, and reinstall the handle. Then, on the inside, scribe "8 quarts" and "6 quarts" and so on so that you will know in the future how much oil you're draining from y our engine.
To each his own..
Works great.
Believe me, I have great tools for jacking the car (Jackpoint Jackstands) but I drive A LOT (30-40k a year) and I change the oil a lot so I just do the job as quickly as I can do it without making any stupid mistakes. With that in mind it's just a waste of time to take the extra 5-10 mins to jack the car or reposition the car on blocks. It takes me less than 20 minutes at this point but I'm getting tired of dealing splashes from a full-to-the-brim oil pan.
