997 "improvements" over early years
Poseur
TPMS became standard in MY07. Optionally available prior to. The DFI engines were MY09 and newer. The introduction of the MY05 997 brought with it several issues that made that introductory year car a little less favorable. The engine (particularly the 3.6 engine) has the same IMS issues and RMS issues as on the 996 cars. Also, assemblers often installed a couple of parts 180º out on the rear suspension which was finally caught in late MY05. The PCM from the MY05 is problematic, and will not play MPs. Also, without a keypad (numerics) it can't handle some of the aftermarket bluetooth telephone systems out there. Do a search within the 997 forum and you will find much more detail on these issues.
Gary
All it takes, SHOULD take, is one look inside the intake manifold of any car with EGR and 100K or so miles. With port injection that EGR residue didn't get deposited on the backside of the intake valve, or was washed off with the injected, EFI gas stream.
