License plate LED bulbs
Anyone successfully purchased one with good results? I have a white 997 and would like to rid of the yellowish plate lights. Just wante one that doesn't trip the computer, reliable, throws out the right amount of lighting, and sourced by a reputable vendor.
Thanks in advance!
Thanks in advance!
Poseur
I can't put my hands on the site right this second but this issue has been discussed both here and on the 996 forums. They're apparently good--don't throw codes at you. Also, you can chose the color temperature of the LEDs you seek. Some are a little too blue while some are dialed back a bit so that the license plate area doesn't ATTRACT attention.
____
Just ordered these:
http://cgi.ebay.com/ebaymotors/Error...ht_3678wt_1014
I opted to go with the 2 SMD units as the 3 is going to be too bright (i.e. lights up the ground).
I just installed my from:
http://www.hoen-usa.com/licenseplate.htm
I got the digital license plate assembly. It says sold out on the page but you just have to email them. The color matches the OEM Audi license plate lights and there are no errors whatsoever.
WHY? who cares? who can see the hue of the license plate bubls?! If it was your fog lights, or something else I understand, but license plate bulbs?! come on!
Poseur
Actually, some of the LED license plate lights are very distracting--both in brightness (intensity) and in blueness. I think it's best to find a set that are bright enough to do the job, and do with with a simple neutral white color.
These will work:
http://www.v-leds.com/Shop/Control/fp/SFV/32481 $14 each
or even these:
http://www.superbrightleds.com/vehic...ting/49/203/56
$2.84 each
Or you can pay $55 a set. Your choice.
